How to Adjust Front Targa Latches?
Received 2,061 Likes
St. Jude Donor '13
After the dealer did all the steps in the GM bulletin (and O-rings) and not fixing my popping/creaking transparent top, I noticed that unlatching the left (front) latch stopped the noise. So they readjusted the left latch slightly looser, and that helped. But the problem is still there somewhat. These are the new style latches.
I'd like to do it myself, but a quick glance in the Service Manual didn't tell me much.
I think the adjustment is done on the receiver that's part of the windshield frame, not on the latch itself which is part of the top.
Can someone give a link or instructions on how to adjust the front latches?
Thanks.
Thanks.
You have to pull the trim piece that runs across the front right under the latch plates (that's what I call them) that's where you can loosen them and move it up or down a little. Just be careful not to adjust too much.
Good luck
Lisa
Good luck
Lisa
St. Jude Donor '13
Thanks, that's what I thought.
How do I remove the trim piece?
And once it's removed, is the adjustment technique easy to see?
I think you may get better results adjusting the rear j-hook latch. Its simple. There is a set screw holding it in place. Loosen that and turn the hook one turn looser. I got rid of a lot of snapping and cracking doing this. If it doesnt help try one turn tighter.
Received 2,899 Likes
I think the trim should just pull off. Not certain but the A pillars do.
I didn't take my trim part off because I was not sure how to do ti. I gently pulled it down and peaked in from the top to see where the adjustment was. It was closest to the rearview mirror. I used a flashlight and was able to loose it and adjust it. It was way easier then I expected.
Good luck
Lisa
Good luck
Lisa
St. Jude Donor '13
Good luck
Good luck
Thanks.
St. Jude Donor '13
Lisa had the right idea. My trim piece seemed pretty firmly in place and I couldn't figure out how to pull it off without perhaps breaking something.
So, with the top removed, I just pushed it firmly downward and discovered that there are two cap screws that hold each receiver into the w/s frame. They take a T30 Torx, my screws were so tight that a normal Torx driver wouldn't budge them. I had to use a T30 "socket" on a 1/4" drive ratchet to get 'em loose, moved the left receiver upward a bit to loosen the tightness of the left latch, and retightened.
Now, I need a warm and bright sunny day to test the results, in cold/cloudy weather the top makes no noise. Not many of those days left around here...
Thanks, Lisa.
Thanks, Lisa.
Thanks, Lisa.
Thanks, Lisa.
Lisa
