Flywheel to rear wheel hp/tq loss between m6, a6
Old 10-21-2014, 12:22 AM
Way2Major
Way2Major's Avatar
Default Flywheel to rear wheel hp/tq loss between m6, a6
I've spoken with many corvette owners in reference to the percentage loss from the flywheel to the rear wheels horsepower between an A6 and the M6. Everyone has a different percentage/numbers. Does anyone in the forum can educate me on this? Been through 6-7 pages and could not find a thread on this subject.
Would really appreciate it. :-)
Thx
Old 10-21-2014, 12:38 AM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
This is not about percentages lost, but on horsepower in general. Well written with lot's of material based facts.
https://www.corvetteforum.com/forums...-ls2-guys.html
Here is a thread on the losses
https://www.corvetteforum.com/forums...ear-wheel.html
interesting read on losses
http://www.superstreetonline.com/how...in-power-loss/
Old 10-21-2014, 01:09 AM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
In spite of the links above, most C6 owners, right or wrong, are saying manual C6s have about a 15% loss, automatics about an 18% loss.
Old 10-21-2014, 08:46 AM
hotmotorsports
hotmotorsports's Avatar
On a 400HP C6, that means an additional 12 horse power loss on a automatic over a standard.
That's a big difference considering how many owners spend hundreds to GAIN 12 HP!
Chuck M
Old 10-21-2014, 10:38 AM
haljensen
haljensen's Avatar
LS2 and LS3 both seem to have about a 10HP difference between Manual and Auto.
No %, just 10HP. Think of the A6 as a pump circulating fluid thru a convertor, clutches and a radiator, it takes 10 HP to drive the pump.
Old 10-21-2014, 12:32 PM
Turbo6TA
Turbo6TA's Avatar
Received 3,087 Likes on 2,078 Posts
2021 C6 of the Year Finalist - Modified
Bone stock with NPP:
A6 / LS3 / 436 hp - 15% = 371 rwhp . . . SAE Corrected (on DynoJet)
M6 / LS3 / 436 hp - 12% = 384 rwhp . . . SAE Corrected (on DynoJet)
Old 10-21-2014, 01:07 PM
KWC6
KWC6's Avatar
But the A6 is faster.
Old 10-21-2014, 01:09 PM
Turbo6TA
Turbo6TA's Avatar
Yup ....
Well, (in most cases) at the drag strip anyway
Old 10-21-2014, 02:31 PM
hotmotorsports
Now that a few have acknowledged what you found, I'm wondering what you wanted to accomplish with this confirmed information.
Chuck M
Old 10-21-2014, 07:22 PM
haljensen
haljensen's Avatar
How about some common sense? IT's NOT a PERCENTAGE! It takes XX HP to move the car, whether that XX HP comes from a 1,000HP Supercharged LS3 or from a 400HP LS2. The driveline loss is fixed and stays the same regardless of the motor HP.
The A6 takes about 10 HP to run the pumps and gears. It doesn't matter if the engine is producing 1,000HP or 400 HP, the A6 still needs 10HP.
The Manual trans works much the same way, The clutch and transmission don't use or need extra HP from a higher HP motor.
Somewhere around 60HP loss for a Manual and 70HP loss for an Automatic.
Old 10-21-2014, 08:48 PM
berk4422
berk4422's Avatar
A6 - 18%, official GM number... I learned this from a friend of a friend who knows a guy that's banging this chick whose brother's friend's uncle works at GM.
Old 10-21-2014, 09:23 PM
Way2Major
Way2Major's Avatar
Hey Chuck, had a choice between a LS3 A6 Z51 LT3 with NPP vs a LS3 M6 LT1; both 2010 with under 30,000 miles. I chose the A6. When I went to a performance shop to inquire about modifying my vette, he stated, among other things, that I should have bought the m6 because 20- 22% hp loss with the a6. Everyone I spoke with had different opinions (numbers) on this issue, therefore I decided to ask the folks in the corvette forum.
Now I have a better understanding about this topic. :-)
Old 10-21-2014, 09:49 PM
hotmotorsports
OK. Great!
For me, I'm an M6 guy so I'm on the good that of that equation!!!
Chuck M
Old 10-21-2014, 11:12 PM
23/C8Z
23/C8Z's Avatar
Received 5,761 Likes on 3,177 Posts
The IRS hurts the car on the dyno.. the M6 vs A6 is a moot point due to the torque multiplication of the torque converter.. In these newer transmissions with 6+ gears an auto almost ALWAYS beats the manual.. unless you're abnormally good at rowing the gears and keeping the car from spinning up in the almost useless 1st gear lol
Old 10-22-2014, 12:57 AM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
An additional factor to include for chassis dyno differences is that M6 cars dyno in 4th gear (1.00 to 1 ratio) while 4th gear in a A6 is 1.15 to 1. If using 5th in the A6 to lock up the converter the ratio drops to .85 to 1.
Old 10-22-2014, 09:15 AM
Boomer111
Boomer111's Avatar
But not as much fun!
Old 10-22-2014, 09:38 AM
hotmotorsports
I've never tried the paddle shift in the C6 Automatics. I guess I should try before commenting, but it would take LOTS to change me from Standard to Automatic Transmission. I've had many pre-C6 automatic Corvettes only to resell them shortly after owning. I just can't do Automatics!
Chuck M
Old 10-22-2014, 09:51 AM
dcarter0001
dcarter0001's Avatar
I would think the double clutch auto would eliminate that difference.
To Flywheel to rear wheel hp/tq loss between m6, a6
Quick Reply: Flywheel to rear wheel hp/tq loss between m6, a6
