Draining coolant on a C6
I don't know what you mean by a closed loop but draining the coolant is simple on a C6.
Take the cap off the surge/overflow tank, jack the front of the car up slightly, put a container (12 quart capcity at least) under the passenger side rear of the radiator and open the petcock.
Received 1,116 Likes
If you are talking about replacing the coolant then you can follow this that I got here somewhere on the forum:
Change coolant every 5 years or 150,000 miles, which ever comes first.
Buy 2 gals Prestone Dex Cool (Walmart) and 6 gals distilled water. I used 5 gals of distilled water this year
and flushed it twice. I think three flushes would have been better.
1) Drain coolant (drain plug is on passenger side). Approx. 8 qts out of 12.6 qts will actually drain.
2) Pull Surge Tank and clean out crud. Refill surge tank to the neck with distilled water.
3) Start engine, idle 4 min
4) Top off surge tank
5) Rev engine at 2000-2500 rpm for 2 more min. (temp should reach ~200 F)
6) Shutoff engine, cool for 20 minutes
7) Repeat steps 1-6 until fluid drains clear (2-4 flushes)
8) Refill with 6.3 qts Dex Cool (it's a slow process) and then top off with distilled water.
9) Repeat steps 3-5, take test drive, refill as necessary with distilled water.
10) Dispose of your old antifreeze at a recycling center.
