2010 Grand Sport: Does it have a Governor?
Does my 2010 Grand Sport Coupe (manual trans with dry-sump engine) have a speed limiting governor?
Retired & lovin' it!
From the 2013 owners manual (page 5-12)
Notice: Fuel shuts off at about
6500 rpm for the base model,
7000 rpm for the Z06 and 427
Convertible models, and 6600
rpm for the ZR1 model.
Received 3,626 Likes
2016 C6 of Year Finalist
Wind resistance is the only limiting factor for top speed on any C6..... Meaning, no governor, just the rev limiter as you go up thru the gears to get there.
St. Jude Donor '12
The post up top is correct where he says it's the rev limiter. That is correct. The Z06/LS7 limits at 7k RPM. The red line in LS3 is 6.5k RPM if memory serves. The program acts as a governor but is a rev limiter to protect the engine. LS9 same.
And the only C6 generation Vette that does 205 is ZR1. Z06 was 198 if memory serves and is drag limited.
From what I have gathered in the past here, resistance limits a stock C6 but if more power is added, the speed limiter would have to be bumped.
No... You guys are making this way more complicated than it is. C6's have no sort of "governor" or "speed limiter".
The cars top speed is only limited due to horsepower or lack of. Adding modifications/horsepower will increase top speed but be aware that nearing 200mph, it takes A LOT of horsepower to keep going because the wind resistance at that speed is great.
St. Jude Donor '12
'Horsepower to get ya there and "torque" to help keep ya there'. The LS7 has lots of that. It needs aero goodies added such as the Z07 package which is very similar to ZR1's factory carbon fiber aero kit that new owners installed or the dealer new owner wanted. And remember that when a lot of down force is added, it takes a lil extra power to continue acceleration. That's where ZR's supercharger shows it's advantage.
The C6 ZR1 is capable (as claimed by GM) to top out at 204 mph, and that's with it's aero package attached. (I had agreed and stated 205 up top-wondering id someone would catch me (j/k).
LS2 is factory limited to 186mph, and in all the above cases, system will start to dis-able via spark if you try to push through, same as trying to push through the rev limiter as well.
Nope, there is no "governor" or speed limiter in the C6 "tune" or the computer programming. This is another thread full of misinformation and speculation......
Not that it matters, because 99.9999999999999 % will never try to find out anyway ...
I saw a thread here a while ago that showed the max speed numbers in the tune tables, but it also said that there are many parameters in the computer tables that are not actually active even though they appear there. I think I remember one poster who replaced the 186 number with a much lower one and then went out to see if the car would exceed it. The car went through the new number with no drama at all.
But...I over this topic!
Like I said before..........Non Z cars are speed limited to 194..........Z cars at 205. Here's a screen capture from my cars VCM.......2013 GS A6 car.
BTW! The Speed Limit ETC Fail at 318mph means the Electronic Traction Control will fail at 318mph............you guys owe me a beer!
