"Check Oil Level" Display Warning Question
Old 11-05-2014, 02:54 PM
JAsVette
JAsVette's Avatar
St. Jude Donor '14-'15-'16
Default "Check Oil Level" Display Warning Question
The "Check Oil Level" on the dash display of my '05 came on today just a day before I'm scheduled for an oil change. Does anyone know how low the oil is when this light comes on or can take an educated guess? Just curious as to how many miles it is safe to drive the car when this warning comes on. Also, does this even mean that my oil level is indeed low or could it just be an electrical issue? Thanks!
Old 11-05-2014, 03:03 PM
cclive
cclive's Avatar
The first step should be to check the oil level on the dipstick...if it indeed low there, then believe the DIC warning. If it is fine on the dipstick then the warning is likely an electrical problem. The dipstick is the final word on the oil level...trust it.
Old 11-05-2014, 03:07 PM
JAsVette
JAsVette's Avatar
Thanks!
Old 11-05-2014, 03:10 PM
unixcorn
Support Corvetteforum!
unixcorn's Avatar
If it is low and you need to drive it anywhere, fill it to at least the low line on the dipstick. It doesn't matter if you are changing it later on today or tomorrow. In my opinion, don't drive it with low oil.
Old 11-05-2014, 09:55 PM
v26278
v26278's Avatar
Mine came on once, I was down 1/2 a liter, which is a little less than half a quart.
I always keep a liter of Mobil 1 in the cubby in the trunk, just in case. My care rarely uses any oil, but does occasionally and in the event it catches me by surprise on a long trip out in the wilds I don't want to have to drive far to find the right oil. I used to drive BMWs and they all dame from the factory with a liter of oil in the trunk, nicely packaged in a little zippered carrying case, that's where I got the idea.
Old 11-05-2014, 10:45 PM
JAsVette
JAsVette's Avatar
Thank you so much! That was the answer I was looking for. And thank you for the good idea.
Old 11-06-2014, 12:27 PM
NoRuls
NoRuls's Avatar
Check the dipstick first. If all's good and you have headers check the wiring by the headers. The wires in my friends C5 melted causing the Low Oil Level light to come on
To "Check Oil Level" Display Warning Question
Quick Reply: "Check Oil Level" Display Warning Question
