Traction Control Service light (Normal)
Cruising
My 09 z06 will light up the 'traction control service needed' if any hard braking or if any wheel spin. Get on it on an onramp that is curved. The "Service Traction Control System" will stay on until the car is re-started. GM tells me this is normal. Does anybody else see this? I have some problem thinking that this is 'NORMAL' behavior, since any use of the traction control will require that I re-start the car. Did Bill Gates buy GM and I did not hear about it?
That is not normal. Next time you get that message, before you turn the car off get a scan tool hooked up and see what fault code is being triggered. It could be a wheel speed sensor acting up, or it could be something else.
Definitely not normal. Who at GM tells you this is normal? Whoever it is should never be consulted again. Sounds like a dealer who is too lazy to find an intermittent and is waiting for a warranty to expire when suddenly this will become far more important to them.
Traction control service light
The issue is not normal. The problem is from a bad wheel position sensor. The repair runs about $200 and needs to be done by dealer. I had the same issue on my coupe. I hope this information helps good luck!!
RJ
RJ
