So I wore my Front Michelin PS ZP's
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
slap down to nothing, could have passed for race slicks.
Just aligned and inspected 6 weeks ago. Had about 4/32s left. Been gone on the road for weeks and came home Wednesday. Noticed the car wasn't tracking well and was quite noisy on the way home and saw why.
I put almost exactly 20000 miles on them. The rears still have 6/32's and look great. I guess the last 4/32 burn off quickly.
Great tires and ordered fronts again this afternoon.
Received 2,092 Likes
Interesting. I ALWAYS wear out my rears before the fronts. No matter what tires, no matter what vehicle.
It does suck when you can only get about 20,000 out of them. It is time for me to replace the GY's that have 22,000 on them.
I have a 2010 GS and changed my rear at 30k and the front ones at 36k (not a smart idea not to do it simultaneously) I would agree there's maybe something else involved in the discrepancy of wear .......
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
As our resident tire expert, "wolfdogs" (Ken) used to say, it depends on many factors including the very makeup of the roadbed itself which differs from area to area. I'm at about 20K miles on the full set of same tires as RLSebring. Wear is quite even, front to back. I do get alignments at least once or more per year, but we will see just how long they last. I also check them from time to time, both with a pressure gauge and a tread depth gauge (the last-mentioned cost all of $1.50 ).
Supporting Vendor
St. Jude Donor '17
Michelin knows the Corvette. The regular warranty is 40000 but because these can't be rotated it cuts the warranty in half to 20000.
I was just surprised the last of the thread wore off so quick. I align 2 maybe 3 times per year. I'm on the road a lot and constantly checking air pressure.
Doubt I could have did anything different to get any more miles out of them.
My experience with my GS on GY's is the fronts wear faster than the rears. Even with the Pfadt standard settings, the insides of my fronts wore right down to the bones, with the rears @ 4/32" on 17k miles. I'm easy on tires, though.
St. Jude Donor '15
"In honor of jpee"
M/C tires on my Harley,I was lucky to get 6000 miles on them. So 20,000 or more on a performance car is not to bad,IMO. I run 3psi above recommended and I'm achieving pretty even wear, with no adverse handling in wet weather. I use nitrogen in tires more for corrosion protection to inside of rims an hopefully help eliminate problems with tpms. Most home garage air compressors do not supply dry air, I think you would be surprised how much water you are putting in your tire. So a trip to CJ'S tire and auto and a free adjustment works for me
Bill
Bill
