Interesting because I just picked some up for mine today. I was trying to watch the harmonic dampener to see if it wobbles this morning, which it does, and the hood came down on me. Glad it wasn't a steel one.
I had that happen while swapping batteries. It didnt hurt much but the shock of getting hit in the back of the head while alone in the garage kinda scared the **** outa me for a few seconds.
Had to replace mine as well. Get someone to hold the hood while you swap them out. Only tool you should need is a flat blade screwdriver to pop the cap open.
Will this work for a 2007? The title says 2005-06 and I want to check before I place the order.
According to the GM Parts Department part # for the struts, there all the same number from 2005-13
Part # 10399704
I would suggest replacing both struts, even if only one is weak, as the other will fail soon.
