car cover and battery tender
How do you guys do it? I'd really rather not have the cord up against my paint under the cover. Any way around this or should I wrap the cord with something?
Use the cigarette adapter, run the cord across the drivers seat (so you don't forget its hooked up),run out the bottom of the door and close the door...
I know it's not rocket science. First year ive put a car in hiberation. I just figured someone had something they may have rigged up for cord management or quick connect on the outside of the car. That's why I lIke this forum.
Check out forum vendor Top Flight Reproductions. They sell an adaptor that is permanently mounted to your car (5 minute installation) and has a quick release plug that mounts to your front grill. Takes two seconds to attached and remove the tender. Does not interfere with a cover. No open hoods, doors, windows. I put a small shelf on the wall in front of my car and leave the tender there all the time, plugged in and ready to go. Pull the car in, attached the connector and walk away. Surprised more people don't use this thing. Probably the best mod I have bought for my car.
I mounted mine with the ring terminals to the battery and fished the other male/female plug down by the radiator - just plug it in and leave the hood and the cover on the car.
The top flight product looks really cool as an option
http://www.qpcpv.com/topflightreproductions/
bingo! thats what i do. i have a cover for the car but never used it in case i want to take it for a short drive, weather and clean roads permitted.
I do the same .... not difficult at all, Top Flight Reproductions has a good idea, I have also seen something called StealthLink
