Tire/Track set up?
Tire/Track set up?
Im trying to find a set of rear DOT slicks for a C6 coupe. 285/35/19 size. Any tire that can help me get my 60ft down at the track. The car is all stock with a 100shot wet kit and my best 60ft is 2.1seconds with a 12.8 second pass in the 1/4. I launch around 1.5K-2K RPM and feather the clutch but still getting wheel spin. I currently have Firestone Firehawks. Im sure these tires aren't great at all. Any recommendations anyone? Thanks
Instead, just put on a trailer hitch, get a small trailer, and trailer the race tires on rims to the track to swap them out there.
I found a set of MT ET streets. The size is 305/35-19. It shows that it fits a 10" wide rim. Do you know if it would rub the fenders if mounted to factory oem wheels? Here is a link.
http://www.mickeythompsontires.com/strip.php
PS I am very happy with my Drag Radials!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Wide body guys go with a wider rim. 19" isn't going to give you enough sidewall in the tire. I think you can also run a 16 inch wheel.. But 15 inch will rub the calipers.
PS I do not think you would want to go with a rim wider than 10" or you would have to change the back space on your wheels and your tires would be sticking out from under the wheel wells. I have a 10"wheel with the 305 12.3" wide tire and I have about a 1/2"-3/4" clearance on the inside and any wider and the tires would be sticking outside on the rear.
19 inch tires are very expensive. You would save some money and have a better setup getting a 17 inch wheel and tire setup. c5 z06 wheels or any reproduction 17x9.5 works. I run a 275/40/17 DOT hoosier DR on a reproduction c5 17x9.5 wheel. They both fit in the trunk too when I go to the track. 1.46 60 foot. 10.78@126.
