Base C6 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 04-12-2015, 02:24 AM
SnipeUout
SnipeUout's Avatar
Do you offer any military discount?
Old 04-12-2015, 06:20 PM
Get_UmJ13
Support Corvetteforum!
Get_UmJ13's Avatar
Originally Posted by Gene Culley
As you can see from the original post where I mentioned the specs there is a considerable difference between C5 and C6 Z51 sway bars. I'd do the C6 Z51 bars with the C6 Z06 shocks.
Gene,
Quick question for you I've considered upgrading my sway bars for a few years now. I just recently bought new wheels and will increase my tires sizes to 265/35/18 and 305/30/19. I have a 07 3LT coupe with F55 selective ride control. If I order the Z51 sway bars do you think I will need the bushings or ends links? My car only has about 30k on the odometer.
Thanks,
Joe
Old 04-15-2015, 09:07 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
We do not offer any further discounts.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 04-15-2015, 09:08 PM
Gene Culley
Originally Posted by Get_UmJ13
Gene,
Thanks,
Joe
You will need new bushings, included in the kit, since the sway bars are a different diameter. If you do not have any noise coming from the current end links and they are not damaged then there is no need to replace.
Old 04-17-2015, 09:07 AM
Get_UmJ13
Get_UmJ13's Avatar
Gene, Thanks for the reply I don't believe I have any noises or issued coming from my current end links so I might be good with those. Does the suspension code play a part in this upgrade at all? I read something a while ago where there were different sway bars for the earlier C6's compared to the later years.
Joe
Old 04-22-2015, 10:02 PM
Gene Culley
Joe
Joe. I wouldn't worry about getting new end links then. The Z51 does have a specific suspension code, but Z51 sway bars are Z51 sway bars.
Old 05-13-2015, 06:37 PM
CitznFish
CitznFish's Avatar
Received 1,350 Likes on 482 Posts
Just ordered the shocks and swaybar/4 end links kit.
2005 Corvette with 160,000 miles (all put on be yours truly) and the shocks and end links are shot.
Will be interesting to see what a difference this makes. I doubt I can tell from how it was when the car was new, but it should be night and day difference from its current condition.
Old 05-13-2015, 09:23 PM
Gene Culley
Thank you for the opportunity to earn your business. You're definitely going to see a very noticeable difference. Please post your thoughts on our upgrade here!
Old 07-04-2015, 10:22 PM
jsmax
6th Gear
jsmax's Avatar
Hi, I am looking to do this upgrade, but was also looking to do springs while I was at it and looking for feedback.
Old 07-18-2015, 02:24 PM
91RS
91RS's Avatar
What size are the stock sway bars on a Grand Sport? Would Z06 or ZR1 bars be an upgrade for a GS?
Old 07-19-2015, 11:50 AM
Gene Culley
The GS already has the ZR1 sway bars.
Old 10-10-2015, 10:27 AM
hotmotorsports
hotmotorsports's Avatar
What about if 2005 Corvette has Z51 factory option, is there an advantage getting the 2013 Z06 shocks?
Old 11-14-2015, 04:17 PM
  #33
Jrigali4
Jrigali4's Avatar
Ive had this on my 07 base for about a month, what a difference (handles like a sports car now)
Thanks Gene! (and thanks for getting the exhaust out too!)
Old 11-17-2015, 10:19 PM
  #34
Gene Culley
Thank you for your business and patience!
Old 01-18-2016, 11:34 AM
  #35
jjbravo1
jjbravo1's Avatar
Based on great service last order, placed an order today for the sways.
Thanks !
Old 01-20-2016, 09:51 PM
  #36
Gene Culley
Thanks !
Thank you for your business and the kind words.
jjbravo1 (01-20-2016)
Old 04-11-2016, 03:04 PM
  #37
fastfreddie78
fastfreddie78's Avatar
Just want to give props to whoever at Cultrag took the time to think this out and put it together.
Out of curiosity, would you know what all is needed to put the F55 MagnaRide system on a base coupe?
I know shocks and the related ECU, at least, but have no idea if the ECU can be integrated or, if it can, how it's integrated. Quick plug-n-play?
For the money, would it be better to just go with other pkgs, Z51, et al?
To Base C6 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 04-17-2016, 09:08 AM
  #38
patrickt
patrickt's Avatar
Thank you for your orders
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
Old 04-21-2016, 07:10 PM
  #39
unixcorn
unixcorn's Avatar
I just ordered the sway bars for my 08 Base Convertible. I can't wait to feel the difference when cornering. Thanks Cultrag!
Old 04-26-2016, 09:26 PM
  #40
Gene Culley
Thank you for the order. The difference will definitely be noticeable. Let us know your thoughts after the install.
Quick Reply: Base C6 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
