Base C6 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
#61
Firmer or molar removing jarring ;-)?
We do not have specifics as GM does not release the numbers (to make it harder for the aftermarket to copy them) and have no way of measuring them. But if you have the base FE1 soft ride then these will be a night and day difference really firming up the ride and get rid of the "boat like" feeling
Can I assume it's "streetable track feel' as opposed to "smooth track only, you'll feel every pebble on the road"?
The z51 sway bar w/ new links might be sweet on a vette w/ 80k miles too!
#62
Received 2,887 Likes
You will feel a big diff because at 80k your OEM shocks are not doing much at all. Mine were wore out at 40k. I am at 175k and on my 5th set of shocks.
Peterk760 (09-03-2016)
#63
I'm too analytical
I have the Z06 shocks and Z51 sways. They are streetable track feel as you say. Firmer than Bilstein Sports but not punishing at all.
I was just kicking around some numbers :
2008 convertible weighs 3246 pounds runs 245 in the front 285 in the rear w/ 435 horsepower.
the 2013 Z06 weighs 3175 pounds and runs 285 in the front 335 in the rear w/ 505 hp.
I'm crystal balling it here... for the 2013 ZO6 there's more Tire (stickier too), less weight ... maybe you can get away with a way firmer shock...
I'll assume was the 2013 Z06 setup ( Shox+Z51 sway) don't leave me to too wild unpredictable setup given 'on paper' 2008 setup...
#64
Z06 has a larger diameter sway bar on the rear than the Z51....front bars are the same. Rear bar affects the front tires, that is why the smaller diameter Z51 rear bar is recommended for base tires.
I ran rear Z06 bar for some time and it is much more centered to drive. Takes more force to turn the wheel. Also there is little to no warning before grip is lost. Z51 sways give much more warning.
#65
Premium Supporting Vendor
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#66
I don't have a wide body but I do have Z06 size tires front and rear (see picture) so can I assume that I should order the Z06 package? I have the F55 suspension on my 2007 which had the Z51 brake package but the base sway bars and would like to upgrade.
#68
St. Jude Donor '15
Haven't been on track day, but sways and shocks just installed. I did notice an improvement going over bumps/potholes.
Evidently my base shocks with almost 80K miles were pretty dead lol
I'll be replacing shocks at shorter intervals from now on
#71
Gene/Patrick I don't know anyone better than you as the top GM parts vendors on the forum to ask this too...but will 08 F55 shocks work on an 06 F55 car? What year F55's are compatible across the C6 generation? Thanks in advance...
#72
They are different but if they can be interchanged we do not have reference to sorry
#74
St. Jude Donor '15
Just did my first road race today. Holy jeebus, the change is unreal. I have a very different car now. The cornering is phenomenal and I was very giddy all 4 sessions. This has to be one of the very most rewarding upgrades I've done to my base Vette. If you enjoy corner carving and don't want to spend thousands...don't worry because you don't have to. This combo is outstanding!!
#75
#76
Just wanted to provide my feedback. Bought the Z51 sway bar kit from Cultrag, and installed it with Bilstein HD shocks. Very happy with the setup, a notecable difference in how my 2013 Base Coupe rides and handles.
Very happy with Cultrag, and highly recommend..
#77
Thank you for your business and the valuable feedback on the kit!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
#79
I am at 50k mi (22k personally, mainly highway)
#80
