Headlight recall confusion, Chevy Customer care
Ok I am so confused.
First off the recall platform campaign # 14203 for corvette low beam headlights inoperative on my 2008. Others have received another recall #13146 as an example, maybe another model year?
I have been thinking that the problem was the wire breaking under the engine bay heat causing the plastic to expand and contract.
My dealership tech says that this is very rare indeed. He has had to replace the UBEC unit before due to other problems but never for the wire breaking. If the wire breaks they would just replace the wire. There have been design changes all the time with the UBEC box with the model years.
So like I said I am confused....
What this campaign does is to correct a higher than wanted grounding current. They add a jumper wire to carry some grounding load. Nothing to do about a wire breaking.
I told him off my information gathered here from Forum members and he scratches his head...repeating what I have already mentioned.
So what is it? Sounds like a few different recalls going on for headlight problems. Maybe model year dependant.
This text was posted in the sticky. I wanted to see if the Forum Customer Care Rep could shed some light.
So re read the information from the Bulletin put out by GM for this headlight fix.
It does mention the heat issue as well as the expanding plastic. It also states the the wire kit is a alternate grounding wire harness.
So maybe I am not as confused as I thought: Use the following steps to install an alternate ground source (jumper harness) to the low beam headlamp relay, located in the Under Hood BEC.
This highlighted information is direct from the bulletin.
https://www.corvetteforum.com/forums...6_dec-2014.pdf
I got the 13146 letter yesterday. It says they will install a jumper wire. I'm thinking its cheaper and faster to do it that way instead of replacing the wire that may break or is broke. I'm thinking its more like a backup wire. If the original breaks the jumper will still complete the circuit.
Electrical is not one of my suits.
If I take it it will be to Findlay Chevy at 215/Rainbow. Have had several good visits there. I'm not crazy about having something fixed that isnt broken. The car is over 10 years old and I would think if it were going to break it would have happened by now.
This grounding circuit (no. 1970) is the one that gets interrupted when the wire breaks inside the UBEC. GM's fix is to bypass the section that runs through the UBEC with a jumper wire. So the "ground" in this case _is_ the signal that activates the low beams.
I'm not crazy about allowing a dealer tech to cut up my car's wiring harness. I would have preferred that GM swap out UBECs with reman units that they'd wire-wrapped in a controlled assembly environment.
I just got my letter and I probably won't be letting them touch my car.
My copper wire was split on the head light and the washer pump.
I found it easy enough to replace the copper in the fuse block and add a backup wire.
GM's quick fix does look like their easy way out.
No worries. The next owner of my car can get the recall done.
The BCM activates the low-beam relay by pulling one side of the coil to ground. The other side is supplied positive battery voltage at all times.
Thank you very much for taking the time to explain this for me and others.
It all makes sense now other than the different recall numbers for the same seemingly issue.
The tread/post count on this subject is just crazy and I have participated way more than my share.
I think we all have a better understanding now.
Thanks for info.
I got a letter in the mail too the last couple of days, looks like it'll take 51 minutes. I will have to get it done in late April or early May when it's out to play.
I also received my letter yesterday. I called the dealer to schedule an appointment and they said it would be 3-4 weeks before they get the part and will call me when it comes in. 3-4 weeks? Really?
Did you want to get GM's fix or did you just want to argue with them about what you thought the problem was? GM saw an issue didn't want you sitting in the dark bitchin' at them, offer a free fix and you go in and argue with them? my 06 has NEVER shown this issue, got a letter in the mail, called the dealer{who I didn't buy the car from} and WA-LA fix applied and I go on my merry way without EVER having a problem, DUH? who gives a happy crap about the rest?
GEE you think you could give them FIVE MINUTES to make 200'000 parts, what you think your green beans are grown in the can?
Race Car Tech
A forum member found the problem (broken ground wire) and ran a new wire to fix the problem.
He also ran a second wire on the under side, so he would have 2 wires in case 1 broke again.
GM will probably just run the extra wire and leave the other in place.
Here is a pic of where the wire breaks with expansion due to the tight turn of the wire.
Resistance of broken circuit
Broken Wire Location
Resistance of Good Circuit
New Wire installed
Extra Wire installed on underside
New Wire installed
I will pass on this BS recall.
Same player shoots again GM..... (with the fuel sending unit next, maybe?)
I've brought cars into the dealer and I had to tell them about the recall or TSB. Then they look it up and say, "Oh yeah. We can do that".
