Shifter Sticks in Park - not a 2005
Hi Gents,
New problem struck me this weekend. The shifter will not move out of park. I have a 2009 and I see from searching this is a VERY common issue on the 2005. I only saw a few non-2005 post with this problem.
I am guessing the main areas to look at are the switches on the brake pedal and the shifter? Not sure if the C6 has two switches on the brake like the C4 but I guess I will find out first before looking at the shifter.
On the 2005, I see there are two solutions. First is you can bypass the lock altogether by tying back a pawl in the shifter but then you loose your park lockout. The other "fix" seems to be replacing the entire shifter for like $700? ARGH! Leave it to Gooberment Motors to not be able to replace just a solenoid.
Can anyone that does not have a 2005 with this problem please chime in and let me know if there is another solution?
Thanks in advance!
EDIT: Actually, I see the shifter mechanism for the 2009 is apparently part number 20916956 and is under $200.
Thanks in advance!
Hi Gents,
Thanks in advance!
Thanks in advance!
Do another search. Your issue is almost always the shift cable.
Received 2,885 Likes
Check with Cultrag Performance. They have a shift cable for $42.
http://www.cultragfactoryparts.com/c...-control-cable
From what I have read it is the cable that goes bad most of the time.
Call Gene and talk to him.
GL
GL
Thanks for the feed back. I was not aware the BCM controlled this. No messages on the DIC. When I press the brakes, I see the rear brake lights do come on. Since the engine starts fine with the brake pressed, I assume the brake sensor is ok?
I see I was not very clear in my original post. I can eventually get the thing out of Park, eventually. If feels as though the shifter is locked Like you cannot push the button in all the way. That could still be the cable? I had a GMC truck where the shifter cable went bad and the first time it went, there was no way of getting it out of park at all. The shifter would move but it could not move the tranny out of park on that truck.
Once I get it out of park, it seems fine. No problem changing gears. Thus I though it was something electrical. It does not occur every time I try to shift.
Race Car Tech
Hi Gents,
Thanks in advance!
Thanks in advance!
I have attached a PDF, which explains why it happens and the fix.
Although my 2006 shifter has been stuck a few times, I did manage to force it out without breaking anything. Since I had my console out to replace the shifter boot, I decided it was time to tie back the pawl to stop it from ever happening again.
Hope it helps.
Thank you all for your valuable insight.
Please see if this makes sense. The car never did this before. I could immediately shift out of park after the car started. It is the button that is locked. Once I get it out of park it shift normally and there is no problem so I don't think it is the cable. If I understand properly from the other threads, the Remote Control Door Lock Receiver provides ground for the Solenoid to activate. Assuming there are no electrical problems, I should see this occur when I take it apart. If it supplies ground and the voltage is there, I am guessing the solenoid is going bad. But one cannot buy just the solenoid from GM. I see part number 20916956 for the whole shifter is under $200. Looks like it can be challenging to remove and is easy to break the tranny cable, but it can be replaced without having to go underneath the car and removing the exhaust, tunnel cover, etc. like you would have to for the cable.
So my choice is to either neuter the lockout as so kindly documented or spend about $200 for the shifter and do a lot of knuckle busting and innovative cursing?
Race Car Tech
Received 1,136 Likes
It wasn't that many decades ago that there was no "lockout" on autos. It is only the result of the more recent "Nanny-State" mentality in Washington that seeks to control everything in our lives, including how we operate our cars.
So far my '07 is fine, but with the first inkling of a shift problem I will take it apart, disable the pawl and never look back.
I have been saving all the threads and documents from this site regarding this problem since I bought my car last year (and am still reading new threads like this one). When/if the time comes I will have all the info I need.
to all!
to all!
I had the same problem with my 2008 and the fix was to replace the expensive shifter. Sorry about that
The Pawl tab locks the shifter in park. I'm not sure a new shifter will not eventually do the same thing.
Hope it helps.
I have a 2008 and with the information I found on this forum I took off the console and it looked like grime and dirt stuck the pawl down. (I have a vert) ... I cleaned and lubed it with with teflon dry spray that seems to have fixed it. It has stuck once since, but a soon as I released the shift lever for an instant it worked again. (I think if you pull on the lever before you get the brake all the way starts the problem.)
IMHO - I'd lube it or just tie it back and save the $200 bucks.
Hope it helps.
I broke my '06 A6 shifter by forcing it too hard to get it out of park.
The new one cost $178 and I DIY'd the replacement.
I had never had my center console out before, but by using the wealth of information available on the Forum I was able to do the swap in a couple hours. Could probably do it in half the time now.
With the new shifter, I find I need to give it a little forward push before pulling it back out of Park. You can give that a try with yours as well.
man...I didn't hesitate to lock that pawl back even tho mine wasn't giving me any problems. it's just that its more than likely if/when it does happen it would have occurred in an inopportune time and not at home in my garage where my tools are. plus...nobody drives my car except me.
Thanks!
It's the same procedure for the 06-13. The Pawl tab locks the shifter in park. I'm not sure a new shifter will not eventually do the same thing.
Hope it helps.
Hope it helps.
Race Car Tech
This was an AWESOME post. Your instructions allowed me to fix this exact issue. I drilled a small hole in the pawl and ran a wire to the center console. This allows me to maintain the function of the locking mechanism yet gives me an 'override' should the issue occur again.
Great job
