Driver's Seat Rail/Track/Base replacement guide
Does a Driver's seat Rail/Track/Base replacement guide exist?
My current one seems to be getting a little worn. It has some play in it, so it sometimes clicks when I accelerate or decelerate. I can make this occur while stationary by pushing myself back or pulling myself forward using the steering wheel. Also, the higher the seat is adjusted, the more it rocks or wobbles. Setting it low helps, but I rather not have the problem to begin with.
Are all the seat rails the same or do I need to find a certain model? My seat is full power and heated. Thanks.
EDIT: I think I found the part numbers. Looks like there are different for Memory & Non-Memory seating.
Memory Part Number - 19293302
Non-Memory Number - 19293301
Still looking for a track/railbase replacement guides. Thanks.
