Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
- How to Swap Your Steering Wheel
Step by step instructions for do-it-yourselfers.
05 steering wheel and shifter swap
ok...all done. thanks to the forum members for the "how to's" for the shifter and steering wheel swap.
got all parts for the swap on that auction site except for the airbag.
shifter from 2010 for $130 shipped
07 steering wheel for $100 shipped
06 clock spring for $80 shipped
06 airbag from forum member for $200 shipped
total $510
smile on my face...priceless.
total $510
Race Car Tech
Nice job on the projects. I also have the changing of my 06 console with something different. I may look at a wrap, or maybe paint a darker shade of gun metal gray. I'm also in the process of making the leather side pieces , like they have on the newer consoles. I think I can get mine to look exactly like those, with the yellow thread.
I can get the leather for around $40.00. I have the patterns cut out on bristol board, just have to add the leather.
got it...thanks
thanks
would love to see how the leather pieces come out.
while knocking around in the garage I found I still have a roll of that 3m di-noc 1080 that I was going to try to install on the console last year. hmm...may not have to use it if I can get the hook up.
Race Car Tech
got it...thanks
thanks
thanks
If not, let me know if you don't use the Di-Noc...I may be interested in buying from you.
Your where not looking hard enough in the parts for sale forum.
Someone was selling pull off late model C6 airbags for around $100 in the last few weeks.
But the real question, beside the looks of the 05 steering wheel, do you feel that the slightly smaller steering wheel feels better than the old one. Trust is, the 05 steering wheel is the only one that was distant to the vet's, and lets face it, now you have a steering wheel out of a cobalt in the vet instead.
can't win'em all tho. and thanks for the info.
btw...do you have an 05 wheel in your vett? If not, I will give you a good deal on the 05 wheel and air bag. pm me if interested.
scale of 1-10 with 10 being the most difficult...I'll give it a 3. the hardest part is removing the 05 airbag. it had 4 access holes where you have to release the bag latches and they can be a pain. but I can explain this process more in depth if you have difficulties.
Pretty straight forward, and comes down to being easy to do, or hard instead.
The steering wheel can either be a bear to remove and may need a steering wheel puller, or will pull right off instead.
https://www.corvetteforum.com/forums...ck-spring.html
If you need to go deeper to replace a bad steering column lock while you are in there (or pull the steering column lock apart to repair it instead).
https://www.corvetteforum.com/forums...ck-2005-a.html
the a6 shifter is a direct swap.
That looks sweet. Was the shifter plug and play?
note: you will only have D and OD and will lose 1&2.
do yourselves a favor and contact chuck CoW and have him tune that a4....you can thank me later.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
So how you like me now.....?
Yeah man! You're gaining BIG points with me on this one!
So how you like me now.....? Compared to that "other" tuner tool you had???
CoW BOOSTER! CASE CLOSED! Chuck CoW A4 tune! CASE CLOSED!
Send me another datalog and let's make it PERFECT!
Thanks for your business!
Chuck CoW
