Rear Wide body wheel Help
Hey guys, I have complete my rear wide body conversion and need some help on tires. Can I run a tire size 265/35/18 on a 18x8.5 56mm rim and 325/30/19 rear tire on a 19x12 rim 59mm with no issues?
I did widebody rear only. On the front I put 275/35ZR18 tires on 18X9.5 +57 wheels and on the back I have 345/30ZR19 tires on 19X12 +59 wheels with no problems.
Shouldn't have any problems with the wheel/tire sizes you are considering.
If you are planning on adding big brakes (Z06/GS/etc) in the future, check with the wheel manufacturer to determine if there will be any clearance issues.
