What to look out for when considering high mileage (>175k) C6?
Cruising
I've come across a 2005 with 175k miles, asking $16,500. Normally I would totally disregard a corvette with such high miles, but it's stock, clean, and has had only 1 owner, which tells me that he probably just really loved driving this car.
How does this price sound & what issues should I be concerned with at this mileage? Should I absolutely get a PPI?
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Rear diff fluid changed to the current stuff made by GM
Check the harmonic balancer
Make sure all other fluids look decent and then change them all if you buy it.
Those are the first items that come to mind. I'm sure others will chime in with other essentials...
Received 2,885 Likes
If properly maintained it could be just fine. C6's run at low rpms on the highway and can last a long time.
I suggest starting it when cold and listen for lifter clatter. Seems that is the first thing to go out on high mileage motors.
I would only consider this car if you are able and willing to spend a few thousand to replace the heads.
I have a 07 with 145,000 miles and it runs like new. Love the car and have no plans to get another any time soon. It has been a great car.
I would get a GM dealer to pull the factory service records on it, to be sure all recall stuff was done, and change all the fluids, as stated above, unless the owner could really convince you that they have been serviced regularly.
Brakes, tires, fluids, belts, and wipers are about all that go bad maintenance wise, and I would search up out here for "C6 2005 issues", just to be sure that you can live with any that come up, since 2005 was the 1st model year for the C6 series.
I have a 2011, and I plan on putting at least 300k on it before I think of getting rid of it. I'll just maintain it well along the journey.
Chris Callaway has over 200k on one of their supercharged C6 vettes, and it is still going strong
Sorry but with that kind of mileage $16500 is a rip off! That car won't sell for more than $7500-10000 I have seen it happen locally a few years ago a dealer listed an 06 with 167k miles and sold it for $7000
Nobody wants a high mileage vette. Your going to be pissing your money away.
But you're right...it might be a tough sell at that price.
The price difference between the one your considering and one with a quarter of that mileage makes it a no brainer. A couple of grand in your pocket now compared to the amount you take out for several of over the top repairs should convince you. This forum is loaded with horror stories about harmonic balancers, weak rear ends (in 05?), bearing failures, electrical problems etc etc.
You'd be better off with a garage queen C5 for the same ballpark money.
All depends on what the buyer is willing to pay.
No way in he!! I would sell my 07 for 7k. Way to nice of a car.
Rapid Fred (05-30-2016)
Received 2,061 Likes
If it seems solid at this time, it'll probably last a lot longer. Most 1 owner cars have been reasonably well maintained. Assuming you can do some of your own repairs then things like wheel hubs and water pumps won't break your wallet. High mileage cars usually get those miles at low highway RPM. I'd much sooner buy one at 175K than a city driven one at half the miles.
I hate to say it, but that price is too high for a car that has an engine that old. Mine is probably worth that but has a brand new ticker. The diff isn't an issue, at this point. They creak even when brand new. I agree about replacing all fluids and belts, unless the seller has documentation that says he's done it recently.
You didn't say if it's an A4 or a manual, but the A4 is solid. If you can get him down to a reasonable price, go for it. It will last for many more years. Just be prepared to fix stuff due to old car-itis (as you would for any car with this many miles).
A good mechanic.
The 05s are great but the mileage would be too high for me. Unless you like to wrench or want to track it and will just be replacing motors/transmissions regularly, I would keep looking.
A good mechanic.
I'd look for a service record. If the current owner has kept up, then you may have a good car there. In addition, I'd personally take the car to a local indie and have him perform a leakdown test. Also get an oil sample and have an analysis done. If the oil analysis and leakdown tests are ok, then the car is solid.
Still, it's an older car and you need to expect to have more wear and tear maintenance than a newer one. I'd not dismiss it out of hand, but I would be more diligent than usual in a PPI.
If well taken care of I would buy it. I did just buy a 05 a4 with 100k on the clock, I paid 17k for it and if you looked at my car and one with half miles and drove both you'd never know which has more miles. At the point that car is at most problems would have already been taken care of I would think. I did however buy my car and replace all fluids accept coolant as the car just had a water pump put on it.
Received 1,674 Likes
Personally I wouldn't look at a car with that many miles. Not only a Corvette but any car.
