Clear Front End Mask
My 2008 ZO6 has a clear bra that goes about a foot up the hood. The same material is on the back sides of the rear view mirrors. I bought it used so I don't know when it was installed. I took it in to my body shop for a door adjustment, and the body guy said I should take the stuff off because it will ruin the paint. I'm not sure if he is right. Some of you guys that have this on your car should be able to help me with first hand advice. Thanks! Doug
Thanks for the response. I'm going to go with your advice. I just can't see how this would hurt the paint. I have learned that trying to remove a bug splatter is almost impossible without scratching the film cover. Doug
I've had clear bras on for over 5 years now on everything from vettes to range rovers and imho, it is the best investment you can make in prolonging the life of your paint. Unfortunately, the guy that told you it will damage your paint doesn't know what he is referring to. I could rip off the film with a heat gun in a matter of minutes without it damaging the paint. I know this, from experience.
I had a front end cover on a car once and it not only left a mark where the cover met the paint, but it also was somewhat discolored. It was the type that had bendable material that angled around the inside corners of the inner front fenders. Those also beat the living tar out of the lower quarter panel. In the end, it would have been cheaper to just have the bumper re sprayed.
Now, I don't get my panties in a bunch over bugs and chips on the front. It's a car.
Not a problem. I have an excellent installer who educates all of his customers before he does the work. I highly recommend Lucas Slick Mist. Every time after I wash the Vette I spray it on and the bugs just wipe off. It's a great product for the clear bra. I normally get it at Autozone.
That will definelty solve your problem. The name took me a while to come up with. The Porsche guys get a kick out of it to. It's actually my license plate.
I don't have that much imagination, but I do love it! I just ended up with ZO6-1. I was lucky that one was available.
I have Expel film on mine and did a lot of research before buying it. It has a 10 year warranty but the installer said usually after about 5-7 years it should be replaced. Quality film absolutely does not hurt the paint. the Expel Ultimate I chose is self healing too. It has to be removed with heat
2023 C7 of the Year Winner - Unmodified
Never a problem with clear bras. They will last 5-7 years and the cheaper ones (usually the DIY types) will yellow over time. They can be removed and replaced when needed. The stretch and leather types will damage paint because they vibrate and rub against the car.
So from the notes it sounds like a clear bra is more help than hindrance; anyone in Southeast Michigan know of a good installer (Macomb/Oakland Township area)? I probably don't need it as the roads in Michigan are world class (yah right!). Brand of bra and installer would be appreciated. I have a 427 anniversary appearance bought used with low mileage and there are a few small spots in the stripe already.
Any issue with installing/removing over the vinyl stripes?
Life Starts at 120 mph
NCM Lifetime Member
I don't think over the stripes would be any problem. They pull and stretch it tight and squeegee it flat. Just my .02 cents worth.
