The actual ZR-1 offset might stick out too far (it is a 1/2 inch farther out offset than '96 GS wheels which were also 11" wide). I may have to test fit this to see if it works!
The 9.5x17 C4 A-mold wheels are the same from a CE, GS, or ZR-1 except for the paint. They're also the 2nd lightest OEM 9.5x17 Vette wheel after the C5Z06.
oh wait... you only want the 9.5" rim? same as the ZR-1 front or z07 wheels from the coupe C4?
correct...so i found some that im about to buy but im waiting on seller to tell me if they are 9 1/2" or 11"....the tires on them are 275's....so i dont know...i asked him to check the stamped size on the back of one of the spokes
11" will be too wide for the rears of a C6..bc of the offset
