Mounting wire to underbody panels
Old 03-27-2015, 12:28 PM
jcabinetmaker1
1st Gear
jcabinetmaker1's Avatar
Default Mounting wire to underbody panels
Im installing under body and LED wheel lights to my 2007 C6 and am wandering if it is OK to drill into under body panels to mount clamps to hold wiring?The panels are under each side between wheels and towards outside
Thanks for your help
Old 03-27-2015, 06:41 PM
hotrodln
hotrodln's Avatar
Well i don't have LED's under the vette, i did help my Son put a bunch under his car...no screws or holes....the adhesive on the back of the lights will probably hold them in place while you use some better glue to make sure they stay there...weatherstrip glue is NICE and sticky...."strong as Nails" in a tube is very strong when it sets up, but you'll need to hole them in place with tape until the glue sets up.
Quick Reply: Mounting wire to underbody panels
