Air filter broken tab
Old 03-28-2015, 06:49 PM
my1970conv
my1970conv's Avatar
Default Air filter broken tab
Hi,
I have a 2007 vert, and while replacing the air filters (closed system - air filter on each side)... when I was trying to clamp the housing I guess it wasn't placed properly and the plastic tab broke on the air intake side when I tried to clamp it. The clamp is fine but the plastic part it clamps to broke.
There are 2 clamps per filter housing so the other one is clamped into place. Do you think I'll need to replace the air intake part where the tab broke or should one clamp be ok to hold it in place?
I have an appointment at GM next week for oil change so I will ask them but I'm sure they'll say to replace it...
Just wanted some other opinions...
Thanks...
Old 03-28-2015, 07:42 PM
Cherokee Nation
Cherokee Nation's Avatar
Duct Tape will work....
Old 03-28-2015, 08:50 PM
my1970conv
my1970conv's Avatar
Yep, I'm sure duct tape will work...
I've been looking online, and it appears that the air filter housing parts are now discontinued...
Might be time to replace the air intake system with a better one... Now the search for which one of the so many that are out there!
I'm sure I'll find one.
Old 03-28-2015, 08:53 PM
Cherokee Nation
Try the parts for sale section.....Good luck
Old 03-28-2015, 10:59 PM
Kenny94945
Kenny94945's Avatar
If it is the alignment tab... an unstressed part.
Orchard Supply/ Home Depot sell a two part epoxy hard plastic glue.
That might work followed by a little flat black paint to blend/hide the repair.
You may be OK, but I would try gluing and if that failed I'd try to find a replacement part on my vette.
Old 03-29-2015, 11:51 PM
gr86ss
gr86ss's Avatar
Originally Posted by my1970conv
Hi,
Thanks...
I have a oem filter housing from my 05 if you are interested
Old 03-30-2015, 09:36 AM
my1970conv
my1970conv's Avatar
Hi gr86ss...
I may be interested... let me private message you...
Thanks...
To Air filter broken tab
Quick Reply: Air filter broken tab
