Battery won't hold the charge, trouble starting.
Yes another battery thread.
I own a 2005 base model, automatic and I love it.
Purchased it in Dec 12, with a new battery. Every winter I disconnect the battery while the car is in storage. Then reconnect and it's always good to go. Even this year around mid March. No trouble starting it, and for the first week, all good. Started every time, then last week I took it out of the garage at work, parked it for maybe 5 min, locked up the studio and came out to start the car and nothing. That damned clicking...luckily there was someone there to boost it.
Got home and stuck it on the charger overnight. Next day it fired right up.
Been driving for the last few days. Parked it Fri evening, took it for a spin this morning Sunday and today it seemed to struggle to start...but it did.
Later, I went to start it again and while still seeming to struggle a bit, it started and showed a charge of 14.6.
Now I went out an hour ago and upon starting it....click click click.
WTF already?
Now it's back on the charger and reading low at about 12.2.
Tomorrow I'm getting a new battery, and from reading around here it looks like the Delco 90 is what's recommended.
My question is this, with the Delco 90 will I still have to hook up the battery if I let it sit for 5-6 days....or will this annoying battery issue still be something I have continue to look forward to?
Sorry folks, I'm sure this has been beaten to death but I just don't know what I'm doing wrong, if anything or maybe it's just time to change the battery once and for all.
Thanks in advance.
David
WTF already?
Thanks in advance.
David
WTF already?
Thanks in advance.
David
WTF already?
Thanks in advance.
David
For 2005 models there was a reprogramming update issued. You may want to see if the flash update was performed on your car. Also, once a battery is discharged, even with a charge, the battery's days are numbered. My OEM Delco lasted 4 years before I replaced it with another OEM Delco. You should be fine doing the same.
It was only on the 05 with manual trans. Some electronics were not shutting off all the way when the car was turned off. It was know as DBS or dead battery syndrome. The reflash addressed and fixed it. My 05 has sat for over 3 weeks with no tender and no problem.
Thanks everyone.
The connections are tight, I just double checked so thanks for that suggestion.
OK it fired up right away this morning, and I've got it with me at work and down the street is a Parts Source dealer.
They dont carry Delco, but say the recommended battery for my 05 is the Exide Performance 86. They also have the 90, but say the 86 is what my car calls for.
Anyone have any feedback on this battery?
Thanks again everyone!
David
David
1 Post
Thanks everyone.
David
David
I just found a distributor 5 min away, called and are now going to be pick up the Delco 86.
Thanks again!
David
