Nicest Widest and Sickest Mud Flaps/Fender Flares? for a C6/nonzo6?
Thanks yall for looking
I love the mud flap styling of the Zo6 and would like to replicate that on my C6. What brand and size is everybody going with? Thanks
What I did in 2007 before GM guards were available, was to get a set of Z-06 rear flairs and cut the inside webbing out to make them a little more flexible to fit the C-6 rear fenders. I had to slightly trim the inside of the guard with a box knife and attached the outside lip with 3-M VHB double sided tape. The inside just attaches with the push-pins like the current GM guards do. the Z-06 flairs will give you more protection and a wider look.
Kewl!!! thanks!
Apsis makes extended Z06 flairs for non-Z06 C6's.
I bought the carbon fiber ones (SERIOUS cash--900+ shipped). The non-carbon fiber ones are cheaper. Around 200-300 shipped, I believe.
You might want to add rear spacers (which can be a pain because you also need new rear studs--which requires pulling the rear hub). Or, you can get a wider tire if you add them.
Here is my set up which I think is pretty unique. Apsis CF Extended Z06 Splash guards, 0.5 inch hub centric spacers, ARP extended rear studs (can't reinforce what a pain in the a** job his was for the DIY'er).
whoa! nice!
^ looks hot
did you get a stock z06 guard? therefore you needed to modify it to fit?
Yup. It's a stock Z06 flap. Very little trimming was needed to make it fit. Go a little at a time and it will come out perfect. I needed them to keep my 315's from sandblasting my quarters.
