That A$$ Stance
That A$$
Stance
Just wanted to share my currently setup and thoughts due to a handful of emails and questions.
2008 C6 Corvette (19k Miles)
Suspension: Lg Coilovers Gt2 (Set on 7 (1-12) firmness)
Thoughts: Lovvveeee the handling! On the track but.. don't kid yourself, there rough as F.. I still love them but i do your research if your daily driving your vette.
Sway Bars: GM z51 sway bars
Thoughts: This the best sway bar setup IF your going to run coil over. Car is on rails and has excellent left to right weight transfer. Very predictable.
Wheels: TSW nurburgrings F:18x9, R:19x10.5
Powder Coated Gun Metal Metalic
Thoughts: Light, Strong, Timeless Design
Spacers:
Front) .25 Billet spacers w/ extended studs
Rear) 1.25 Billet adapter
Thoughts: Track Tested, work perfect, very strong.
Tires: Continental dw's F:245 40 18 R:285 35 19
Thoughts: WOW these tires grab the road like glue! Extremely impressed with autocross and track days.
Other Mods include: Halltech intake, bottom seat foam kit and seat track repair kit, M2W, led interior light kit, centennial edition suede steering wheel, oem Z06 booty, flares, and z06 spoiler, etc..
Hope y'all like the review! If you have a strong opinion and don't agree i don't care lol.
Thanks for reading,
Brad
Goodyear runflats
Spacers:
Thanks for reading,
Brad
Goodyear runflats
Kind of lost here,
Looks like you had the room for wider rims/tires (wide body car), but used smaller width tires and spacers to bump them out instead (losing inner space for the wider tires)????
All this seems counter productive for a semi track use car, since with the LG coil over in play, could have went to wider rims/tires, and instead of limited on what you can use the Z-51 sways for due the limited grip of the smaller tires, would have had the tire grip for Z-06 sways instead.
As for the rim spacers, not sure how well these are going to get along with the wheel hubs on a hard track pushed car before they give up the ghost. Really, looks you have the room for 255's front, and then 305" rear to match the set out without the needed of spacers ( Or even wider rears is you are really pushing the car hard out turns to justify the extra meat in back).
Kind of lost here,
Looks like you had the room for wider rims/tires (wide body car), but used smaller width tires and spacers to bump them out instead (loosing inner space for the wider tires)????
Do you have coilovers? Ive actually added a little bit of preload to give the rear shocks more travel. Called LG and they are setup correctly. Great handling
just on the rough side.
