Anyone Done the S2T Paddle Shifter Conversion
I remember someone was in the process of converting the paddle shifters from the stock paddle to the custom S2T paddles along with the F1 shifter module. Wonder if they have completed it and had any pictures. I plan on being cheap and doing the wiring change and then adding the new paddles.
I just did the F1 paddle shifter on my 2007. I was not aware of the S2T paddles. I just checked their website and I may have to add these next. If I do I will let you know.
FYI I purchased my F1 paddle from a forum vendor. The installation took maybe 15 minutes. It has been a month and really like the conversion. I use the paddles all the time now.
Chris.
Chris.
I have the paddles and installed them on shifters, but they have not yet been installed in the steering wheel. ( I have a spare set of shifters). I hope to install them in the car next week.
They are a quality product and they installed into the shifters perfectly, snapped right in and I could trigger them on the bench.
I too am just going to swap the 2 wires in the right side wire connector instead of buying the pre-modded "F1 module"
Thanks for the feedback. Great to hear!
You've found the inexpensive way to achieve the 'F1' shifting performance.
We look forward to some pictures of the Paddle Shifters installed!
Michael Bello
S2T Performance Products
Also which paddles did you order? I am thinking that the CH1. B1. S will be the ones I order.
IMHO I didn't like the B1 style because the top half was longer then the bottom half. I'm sure they are a copy of an OEM from another car but it just looked off it me.
I will post pics when installed. As it seems there are not many installed pics available.
This post just cost me $2k...lol
I've been on the fence and just ordered my new SW and new SRT Paddles.
I two have a spare wheel (thanks to a forum member).
So I will soon have a 2 two tone titanium /black SW with matching 2010 GM carbon. (like this with one, but different colors and carbon) and new Polished Silver B2's installed in 4-6 weeks.
I'll be swapping the 2 wires as well, already done on my spare.
I have a stock wheel I have converted that I will sell if anyone is interested in it? Not sure what the going price on these are. It's in great shape and has all the controls on the wheel. I just put in one of the Suede wheels.
I'll put an link in the For Sale items as well.
Is achieving the 'F1' performance accurate ?? or does this set up just allow you to operate the upshifts and downshifts differently ? I mean this doesn't make the tranny shift any better does it ??
Thank you for your Post.
The actual transmission shifting performance is unchanged. An aftermarket 'tune' would be needed to alter the transmission shifting speed and performance.
The Paddle Shifters themselves are meant to improve the shifting experience by giving the driver a proper and larger shifting surface in which to engage the transmission. The 'F1' module (or 'F1' wiring modification) is recommended so the left Paddle Shifter downshifts and the right Paddle Shifter upshifts when depressed.
Kind regards,
Michael Bello
I ordered my new paddles yesterday. Expect then early next week. My '07 coupe has already been tuned so the transmission is much faster on the shifts. I am doing this so I have the down shift on the left and upshift on the right. This is first accomplished with the wiring change or the F1 shift module, the new paddles do a couple of things. First you no longer have those ugly little buttons with the + sign on them sticking up second you get more paddle above and below the wheel. I do a lot of SIM driving on my computer and I use the paddle on my computer wheel. I have found my self down shifting when I meant to upshift in my '07, simply because the paddles in the C6 were not designed to operate as most paddle shifters do. I know the C7's are now set to do exactly what this will do.
Actually the tune was done prior to me owning the car. The original owner has American long tubes, hi-flo cats and cold air intake installed and a tune. I love how it shifts, 1st to 2nd under hard acceleration and it jumps sideways and 2nd to 3rd it a neck snapper. I will be glad to get the new paddles installed next week.
I received mine Monday and installed them tonight. The fit and finish are outstanding.
One item to note is that receiver pin is spring loaded and can fly out, mine did but I was lucky and had a spare paddle unit I was able to cannibalize. The installation took about an hour including looking for the lost recieved pin and getting the pin out of the other paddle.
I will post pictures.
Chris
Chris
