Two #1 Key Fobs
Two #1 Key Fobs
I tried to program 2 #1 Key fobs on my 06 c6. My normal fob works fine, however the "new" #1 wont unlock or start the car. If I try to add it via the glovebox slot, the DIC says its a known fob. I changed the batteries out to make sure.
So can you have 2 #1 Fobs on a C6 or does it need to be a #1 and a #2 fob?
Only fobs that are programmed as #1 or #2 can access the memory options of the car. Fobs programmed as #3 or #4 can only lock and unlock and start the car.
So thats my point
The two fobs I have, are both engraved with a large "1" on the bottom.
I have my "normal" fob programmed as the Key Fob 1 after wiping all other fobs, then I used my "new" fob as Key Fob 2.
I can now start and do all cool things with the "normal" fob, however with the "new" fob, nada. So I assumed I pooched the process on that fob, so I thought I would add it again. So when I place it in the slot in the glove box it tells me its a known fob. However Unlock, Lock and start all dont work on the "new" fob, despite being a known fob.
So I changed the battery out and removed any electronic devices from my person, still no good.
Any help, or do I wipe the fobs again and start over
There are 2 different procedures for programming fobs for the car.
One is a "short" procedure that just adds additional fobs to the car. Those fobs that are added are automatically added as the next fob number that has not already been programmed for the car. If the fob you are trying to program has already been programmed for your car, this procedure will not reprogram it as a new fob number. Once a fob has been programmed as number 4, no more fobs can be programmed for the car.
The "long" procedure reprograms ALL the fobs for the car, beginning with fob #1. Remember that it doesn't matter what fob number is engraved on the fob, the first fob programmed will be programmed as fob #1. The next fob programmed will be programmed as fob #2, etc, up to a maximum of 4 fobs.
So, if you've got a fob that's already programmed for the car as some number other than #1 or #2 and you want the 2 fobs you have to be programmed as #1 and #2, you'll need to use the "long" procedure. The other thing that the "long" procedure does for you is to cancel all previously programmed fobs for your car that you don't have.
Start over with the long procedure.
At this point I decided on the long process, using my "normal" fob as Fob 1 for the car, then the new fob, as fob 2 to the car.
Now, the car functions fine with my "normal" fob, however the "new" fob does nothing. I assumed I screwed up the set up, so I thought I would do the short process to add the new fob, however when I put it in the glovebox slot on the short process, the DIC shows a message saying "Known Fob"
However using the lock, unlock, trunk or alarm buttons nothing happens. When in the car with the "new" fob, the car wont start.
I'm guessing im wiping all my fobs (long process) and starting again, right?
I don't know what else to tell you. It sounds like you've got a glitch in your use of the long procedure to program all fobs. There are others here on the forum who are "experts" in these 2 procedures and should be along, probably tomorrow, to help you.
Thanks for trying
Good/correct info from Vette DD on all of this.
Search for threads on the long programming sequence and confirm you aren't missing something and/or not getting the proper confirmation from the car.
Last resort, have a dealer do it.
You are saying you have a "new" number 1fob. Did you have the original two and lost/replaced one? If so, the computer acknowledges two fobs for all the settings, so if this is the "third" fob it cannot be programmed as the first two... Does that make sense?
So I tried the short process, and I had the Max number of fobs message.
I agree with FortMorganAl...it sounds like you have properly programmed both fobs but the second (new) one has a dead battery or the battery is installed wrong. The slot is recognizing it, so it programs fine, but without a working battery it will not do anything with the car. I would suggest putting the new one in the slot and trying to start the car. If the slot recognizes it enough to say KNOWN FOB, then it will also start the car when it is in the slot. Your symptoms are completely consistent with a working fob that is not getting power from its' battery. You can put a label over the number 1 that says "2". As stated above, all fobs are the same...the number stamped into it is only for your convenience...just change it to a "2" and it will now be a "2".
Do not start programming again...the steps you have done already show that both fobs are programmed properly. The fact that your original fob starts the car shows that it is programmed. The KNOWN FOB message shows that the new fob is correctly programmed. No more programming is needed.
Another spin to this.
Some stores (Home Depot) have some device by their battery section that you hold up your fob to and press any button. The device hears the signals and flashes a light to tell you that the buttons work or not, primarily to check battery life on your fob only. I suppose this would tell you if the battery is installed properly, let alone if the fob is any good in the first place.
