Top of my door panel is loose?
Old 04-04-2015, 09:01 PM
06blackvert
06blackvert's Avatar
Default Top of my door panel is loose?
I just noticed that the passenger side door panel is loose on the top. Is this an easy fix and do I need to take the door panel off to fix. I haven't really looked at it...Just wanted to get some direction before I look at it in the morning.
Old 04-04-2015, 10:30 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
You will have to remove the panel in order to tilt the top of the panel out a bit to get the (4) metal hook clips installed at the top.
This is most likely your issue.
http://www.theredlion.us/DSV%20Passe...%20Install.pdf
Old 04-06-2015, 10:50 AM
LbulletM
LbulletM's Avatar
I literally did this to my driver's side door weekend before this past one. I had a squeak. Took about 10 minutes to take the panel off (including looking up how to do it), 5 minutes to wrap a few parts in teflon (I'd suggest it, it was easy and helped in tightening everything up), and another 10 to get the hang of putting everything back together. You should have the window down when reinstalling and you can kind of flex the door panel near the top to get the hooks seated well. My door now sounds a lot more solid and the squeak is gone! It was a better mod than my HUD!
To Top of my door panel is loose?
Quick Reply: Top of my door panel is loose?
