Temp gage
Old 04-11-2015, 02:49 PM
kyzerd
kyzerd's Avatar
Default Temp gage
Ok need help. My outside temp gage is stuck at 38 degrees. Anyone have that problem help.
Old 04-11-2015, 04:03 PM
Rebel Yell
Rebel Yell's Avatar
Received 2,639 Likes on 1,702 Posts
At times it takes quite awhile for mine to catch up with the outside temp. I'm sure you've tried a long drive, so maybe you could unhook the positive battery connection for a little bit. Maybe it will reset. Wish I could help more. Good luck.
Old 04-11-2015, 04:10 PM
usdmpwr07
usdmpwr07's Avatar
First step, move out of Michigan
Second step would be to check out the sensor itself and make sure it's clean. I would tell you where it was but I don't know.
Old 04-11-2015, 04:30 PM
Rebel Yell
Rebel Yell's Avatar
Thanks brother. I just saw a post on how to check the sensor. Only wish I could post it for the OP. But, I'm quite technologically challenged.
OP, do a search in this section for thread heading "Outside air temp stuck". Everything you need to know is there.
Old 04-11-2015, 05:39 PM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
Try pressing both defrosters and the fan up buttons simultaneously (three buttons at the same time). This makes the sensors update the climate control module immediately. Worth a shot before digging into anything.
Old 04-11-2015, 06:36 PM
87SAM
87SAM's Avatar
https://www.corvetteforum.com/forums...emp-stuck.html
Old 04-11-2015, 07:54 PM
Mad*Max
Mad*Max's Avatar
Received 1,494 Likes on 815 Posts
this...my car has been doing this intermittently since new and this feature always works
Old 04-11-2015, 10:15 PM
kyzerd
kyzerd's Avatar
Thanks guys I will try all ideas. Love to get out of mi. Top down today for the first time this year!!!!!!!!!!!!!!!!
Old 04-12-2015, 01:53 AM
ProfessorDeath
ProfessorDeath's Avatar
St. Jude Donor '13-'14
Usually takes 5-10 minutes of actual driving for the reading to update. If, after that, it's still throwing odd temps, use the reset procedure.
Old 04-12-2015, 07:24 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
The sensor is very near a potentially hot radiator. Therefor the software refuses to increase the temperature reading if the car has not been moving for a while. It will decrease the temp quickly when you pull out of a heated garage since it knows that is a real change but increases might just be from the radiator if the car is not moving fresh air across the sensor. If you are just admiring the car sitting still the temperature reading might not be right. DRIVE IT!
Old 04-12-2015, 09:02 AM
Red08
Red08's Avatar
Received 1,439 Likes on 778 Posts
My temp gauge sometimes takes a few minutes to properly read the temp, but it has never been stuck on any temp after a few minutes.
To Temp gage
Quick Reply: Temp gage
