Will a size 305/35/19 Drag Radial Fit om my 2013 C6
Old 04-19-2015, 03:04 PM
1bad99vett
1bad99vett's Avatar
Default Will a size 305/35/19 Drag Radial Fit om my 2013 C6
Hello All,
I want to put a set of Mickey Thompson ET Streets size 305/35/19 on my 2013 C6 corvette. Will these fit or will I have a problem with them rubbing or causing any damage to my vehicle? Are these tires any good. Please advise. Thank You!!
Old 04-19-2015, 05:54 PM
SoSlow1
Support Corvetteforum!
SoSlow1's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Originally Posted by 1bad99vett
Hello All,
Yes they will fit. I never had a problem with them rubbing and the tires do work well. I've run 10.24@ 139 with a 1.55 60' with that size. As far as damaging your car that's going to be on you and how you treat your car in my opinion.
Old 04-19-2015, 07:32 PM
1bad99vett
1bad99vett's Avatar
Originally Posted by soslow1
yes they will fit. I never had a problem with them rubbing and the tires do work well. I've run 10.24@ 139 with a 1.55 60' with that size. As far as damaging your car that's going to be on you and how you treat your car in my opinion.
ttt
Old 04-19-2015, 10:33 PM
1bad99vett
1bad99vett's Avatar
Thanks for your reply. What kind of modifications do you have done to your car. It runs real well.
To Will a size 305/35/19 Drag Radial Fit om my 2013 C6
Quick Reply: Will a size 305/35/19 Drag Radial Fit om my 2013 C6
