Check out this oil test!!
I always heard good thing's about Royal purple, but this test is really cool!! It's a Very well made video to compare motor oil, VS bearing wear!! I Bet this stuff would work Great in corvette motors?? I know, use ONLY MOBIL 1!!! But there are many out there, that say it's really not the top oil as some may think?? But I have read that Mobile 1 is specially engineered for tight valve areas and lifters just for corvette motors? Why wouldn't any other better synthetic oil work? Or may work even better then mobile 1?? Just food for thought?? I want the BEST for my girl!!
You can't go wrong with amsoil.
Royal purple is garbage. Mobil 1 is good. Just because GM recommends it and fills their factory cars with it, doesn't mean it's the "best". It is good oil though.
But i am going with amsoil in my next oil change.
if you are genuinely curious about a certain oil for your car, head over to bobistheoilguy and look up oil analysis samples of the oil type in question on the car in question. you will find many people have already tested the combination you are thinking of and you can buy a little piece of mind with the discussion and sample results.
from there, if you choose, you could send in your own sample for analysis, after a couple of fill ups and tests you can get some really good data on how your car is wearing.
.. and while I am no expert myself, and this cannot be definitively answered as "this oil is always good for every car" - amsoil has scored highly for every car I've owned and put it in before. wrx, sti, mustang, camaro, 350z etc... I've not yet researched it for the vette.
Oil Test Royal Purple Vs Amsoil - YouTube
Did you even watch the video?? Because amsoil bearings failed faster!! I mean even after he took the oil off the bearing it still ran with more friction than amsoil, that was submerged in oil!! I don't think you watched the whole video? If you did, How can you call it garbage?? It Worked very well for me in Motor cross bikes.I'll tell you what, those motors get SUPER HOT when I used to race bikes!! Royal Purple held up and worked better then many other synthetic oils I've tried. I'm not a sale rep, but I have used the product and disagree with you!!
Didn't we see the same contraption in the Slick 50 infomercials?
First off you look at the oils they're using. Top of the line RP vs bottom grade amsoil?? lol
Then look at how he puts the weights during the amsoil test, then during the RP test.
Then i want you to go on BITOG.com and look for UOA reports by RP.
Shall i pull up my reports using RP?? I have used 3 different grades of RP in my LS2 GTO.
Wanna know what it gave me?? INSANE COPPER NUMBERS.
What does that mean? BEARING WEAR.
Ok
Yes i've watched the video. As well as the same BS test other companies use to sell RP.
Yeah, go see Bobistheoilguy. All you ever wanted to know and more.
Pilgrim
That's just how it is. Your research will be your guide and only you can make you decision on what you will end up putting in your engine.
If you put RP and you like it, then that's all there is to it. Some people have had good results, others haven't. If you do your research, more people have had bad results than good with RP.
With amsoil, more people have had good than bad.
I ran rotella after i ran almost 2 years of RP in my LS2 GTO, copper numbers improved. And Rotella t6 is only a group III oil. And it still put up better numbers than the 3 model RP oils i've used. Then again this is MY experience. The way i drive my car, my engine health, where i live, how i use it, how often i use it etc etc. Those factor in in what oil you use and how it wears down.
Like someone said, these days, basically ANY synthetic oil is good enough for a street car. Unless you're entering the rolex series or doing 24 hour of lemans, any off the shelf synthetic is perfect. It's only a GM engine, not a hand built ferrari engine or something lol
Oil is oil for us. Use what you like, like what you use. If it's RP, then it's RP. Stick with it.
