Rear view mirror courtest light C-6 coupe
7th Gear
The interior rear view mirror courtesy light will not go off.
The on and off switches next to the light do not operate the light.
I had to remove the wire that connects to the rear of the mirror.
Does anyone have a solution?
The button to turn them off is in front of your left knee. You probably hit it getting in or out of the car and turned them on.
I've not installed any interior LEDs, but we've had several posts from forum members that they work that way.
Hundreds of posts about that button. If you're not running the LEDs, press that button ONE TIME while the engine is running and release. You will not see an immediate effect, but it will solve the problem. The mirror map lights will go out when they should.
You really should have posted here about the problem first.
