DIY Power Caliper Piston Compress Tool
Old 05-05-2015, 05:15 PM
Boxcar
Life Starts at 120 mph
Support Corvetteforum!
Boxcar's Avatar
NCM Lifetime Member
Default DIY Power Caliper Piston Compress Tool
Ok, the pictures pretty much tell the whole story.
1. 6 inch C-clamp
2. One piece of 3/8 hose about 3/4 inch long
3. Old 1/4 drive 9/16 socket
4. 3/8 to 1/4 inch drive adapter
5. Power drill
Cut the T-handle off the C-clamp
Press the hose onto the shaft about 1/4 inch. Do not press it on all the way, because you can't get the socket on.
Place socket over the end of hose and press it onto the shaft. I used a vice, but a hammer should work.
Done.
Edit: Set drill/driver to a low torque setting, reduce chance of any piston damage when it makes contact in the back of the sleeve.
So far, I've used it three times, I track so I do caliper maintenance regularly, with no issues so far.
Your new Power Caliper Piston Compress Tool.
Old 05-05-2015, 05:46 PM
v1 rot8
v1 rot8's Avatar
Great idea, thanks
Old 05-05-2015, 06:47 PM
ls1121
ls1121's Avatar
St. Jude Donor '14-'15
I use a screwdriver, sometimes two, used this method all of my life and have never had an issue.
Old 05-05-2015, 07:19 PM
okie08vette
okie08vette's Avatar
Pretty cool, I just use the c clamp t handle since I don't have a need to do this often. I would be worried that I would but to much pressure on the pistons with the power driver.
Old 05-05-2015, 07:24 PM
Boxcar
Boxcar's Avatar
NCM Lifetime Member
Agreed on the pressure....
I edited my original post with a couple of after thoughts.
Old 05-05-2015, 07:25 PM
Boxcar
Boxcar's Avatar
NCM Lifetime Member
I assmume you are talking about a power screwdriver?
Smaller tool with less torque?
Old 05-05-2015, 07:34 PM
wayback
wayback's Avatar
Received 2,882 Likes on 1,905 Posts
I just use the C clamp and an old pad. Keeps the clamp off the piston and applies even pressure.
Good idea though. Give you an A for a well thought out design.
Old 05-05-2015, 08:46 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
Great solution and ingenious idea.
I have used a C-clamp in the past with a small block of wood or used pad, but I find that 2 flat screwdrivers are really effective to compress the pistons before I remove the bolt to undo the caliper.
Old 05-05-2015, 10:31 PM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
Or you can buy the actual tool that is made for the job at Harbor Freight for $7.00.
Old 05-06-2015, 12:50 PM
RC4G
RC4G's Avatar
Or leave the t-handle in the clamp (so it can still be used by hand) and just notch an old socket with a grinder that you can then slip over the T?
To DIY Power Caliper Piston Compress Tool
Quick Reply: DIY Power Caliper Piston Compress Tool
