Lean on both banks?
Lean on both banks?
Fellas my brother took my car in for a NC inspection and the service station told him it was throwing two codes and it was lean on both banks, making the check engine light come on. My car sits 95% of the time because I am overseas with the AF. What could be the possible cause? Any help would be greatly appreciated!
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
IDK, but here's a bump===someone will pick it up as a topic.
Lean both sides is usually an air leak.... un-metered air is making it into the engine.
Vacuum leak, or intake leak. Any mods? The LS engines have been known to suck the intake gaskets in. I have a 6ltr with this exact issue...
Come to think of it, this started shortly after I had a VMax ported ls3 intake manifold installed. The shop reused my gaskets. This could be the culprit. I was unaware of the engines sucking in the gaskets. Other than that, the only other under hood mod is a haltech kb and lg headers.
Its either an air or vaccum leak or a fuel issue. If its both banks, then any fuel issue is likely related to pressure from the pump, and any air or vacuum issue is likely at or ahead of the entry to the intake manifold. First thing to check is the recent intake installation and make sure its all snug with no leaks. It could also be that your tune or ECM calibration is not correct given the extra air-flow from the ported intake. Is a re-tune generally needed with that installations and did you re-tune?
Really, they used the same intake gaskets???? Saved $50 +-,,, there's a good idea! Time for a new shop!
MAF issue will throw lean codes as well. Check to ensure it is correctly installed (ie; not upside down, loose, etc) then your tune. My '08 had both codes for several months. BG engineers finally chased it to air leaks causing turbulent flow across the MAF. Sealed leaks using metal AC tape and codes haven't returned for 7 years!! Stock air intake and no mods on the car.
A little trick a mechanic would use is to spray around the intake and throttle body with 2+2 or brake cleaner and listen for a jump in idle. That would indicate an a vacuum leak. If it's a small leak it might not change the idle so you'd have to have a scanner that would read live data, or an air fuel gauge and watch that to go rich while you're spraying the gasket areas.
PS that stuff is highly flammable so be careful.
Also, I've seen some cars only leak when cold or warm. Sometimes the temperature change is enough to open or seal a small leak. That's unlikely, but stranger things have happened.
Sheesh, I didn't realize OSHA was monitoring the forums.
Most of us are backyard mechanics looking for backyard fixes. The safest way to check for leaks is to get a smoke machine and smoke the intake system, but a can of brake clean is a tad bit cheaper.
1. Check for a vacuum leak, fix the leak if found.
2. Clean your maf. The KB design can cause turbulence across the maf. Changing the intake may have been enough change to cause the issue.
If no vacuum leaks are found, and you cleaned the maf, and the lean codes come back. Change the KB to a MF air intake with the maf forward design.
FYI, my car could not run the KB at all, my fuel trims were all over the place throwing lean codes. The MF103 cured that.
Good Luck,
DJ
Good Luck,
DJ
Thanks for the insight fellas. My brother took it back to the shop and they did the smoke test. It was the intake gaskets. A new set was installed and seems to have fixed the issue. A street tune was done also and all the codes cleared. I will take extra precautions like cleaning the MAF when I get back stateside. Thanks again!
When I'd read shop reused the gaskets my first thought was there's the likely issue. But everything's good, shop found the issue & stood behind their work.
As for the MAF, if it isn't malfunctioning I'd leave sleeping dogs lie.
Yea, gutless I am.
