Leaking oil pan pics please
I have read threads about how common this is with the C6. It made me check my car, and my 2012 is starting to weep around the front passenger side bolts, and the upper and lower pans have a oily film on them.
Can we get some pics posted of different degrees of oil pan leaks? What are some pics that would be borderline to being necessary to be taken to the dealer for a drivetrain warranty replacement? How about some just starting to show a leak. What are some really bad ones?
Sorry but no pictures of my leak prior to repair. As I remember it, thin residue of oil on side and around bolt holes on passenger side. Blow by on parts of car behind pan but not wet. More like a thin film or stain. Repaired under GMPP. 2008 model. Leak occurred in 2011.
Can you get at all of the pan bolts without moving the steering rack or did you just re-torque the ones you could get to? Assuming several cannot be reached but you said all. Just curious.
Good question....I didn't do it...the Chevrolet dealer that services the car did. I hope so....))
My 08 had the leak repaired under wsarranty at about 36K. I don't know if the pan has a gasket or uses the same sealer as the new LT1 engine. If it uses a gasket it might be possibe to re-tourque the pan bolts. If it uses the sealer then it will have to be removed, cleaned and resealed. I would check with the parts counter to determine if a gasket is used.
I had the car inspected yesterday after ~ 1,000 miles since I had the oil pan bolts re-torqued. Perfectly dry..))
