Power Steering help??
This is a weird one. I started to notice noise in the steering when making turns at slower speeds and the wheel turned harder. So I checked the PS fluid level. Whoa! I found it to be basically empty. Here's the odd part. I have never ever noticed any sort of drippage or anything under the car and I don't see any sign of excessive oil etc in the overall engine area. At least from the top...
Any ideas? that stuff doesn't just evaporate over time right?
Check the hose where it connects to the PS Rack. I had a small leak there and the fans were blowing it back on the engine; it wasn't a big leak, but over time it would drain the resevoire.....
Just experienced the same exact thing.
Did you discover the problem?
Rick
It is common on vettes that the steering rack oil lines will seep, look from the top on the drivers side with a flash light at the connections. Mine was leaking from the factory, tightened them and problem solved. It is small enough not to be noticeable but can add up over time.
Shame on me for never checking that (PS) fluid. I'm in there once a month to do the Ranger method on the clutch. I have no idea how long the reservoir was empty. Never looked until the pump groaned. Got the car home (couple miles) shut it off and ordered some AC Delco fluid on amazon, which will arrive tomorrow. I'll fill it up and cross my fingers.
Rick
Originally Posted by COCO RICK
Thanks for the reply and advice. First thing tomorrow I'll check that out.
Rick
Rick
