Zaino?
Zaino?
Ok guys, I have been browsing the detailing section and everyone is so sold on Zaino I am ready to try it, however, which one? There are several Zaino products.. 2011 Grand Sport BLACK
It all depends on what you want. If you want a simple one coat and done product then get ZAIO (All in one). It's like any other product, put it on and wipe it off.
If you like the idea of layering product Zaino recommends Z5 for dark cars. Personally I like Z2 better as I think it has a better shine to it. Zaino recommends the ZFX if you are going to do multiple layers on the same day. If not you don't need it (though Zaino will recommend it).
Then there is ZCS (Clear Seal) that you wipe on and walk away. I just started using this product and am very impressed with it. I have used it on two cars (and my mower ) and I've barely used any out of the bottle.
A lot of guys now just use ZAIO and ZCS. I think it's a winning combo and will give you a great shine. Z6 is a detail spray which I would recommend getting over the Z8 (a better detail spray). IMO there isn't enough difference in the look to justify the extra cost of the Z8.
So these two and call it good? Thanks for the reply. Oh and the paint is in great condition already. Just looking for that protection and shine.
As a long time Zaino user I recommend Z2 (sealant), ZFX (catalyst), and Z6 (detail spray). If your paint is in good condition the AIO (sealant with mild polish) is not necessary. I use the AIO on my daily drivers. I have many of the Zaino products in my arsenal. I agree with the prior post it is hard to justify the higher cost Z8 detail spray over Z6. I use the ZCS (clear seal) as well but I get better results with Z2. I also use Z7 (wash soap). Good luck.
BIGMAC
BIGMAC
BIGMAC
BIGMAC
OP was asking about Zaino let's not confuse him like every other thread that turns into a big debate over what's better. Everyone has their opinion. IMO Rejex is not better. I actually use it on my DD and it doesn't last as long as the Zaino on my wife's DD. I also find it harder to remove than Zaino for some reason and once again IMO Rejex has a more "plastic" look to it and Zaino (IMO) has a deeper shine.
You'll get a lot of opinions on this topic and that's all they are, opinions. There is no "best". If you want a simple on and off product and want to try the Zaino line then I'd just get the ZAIO and some Z6 for the detail spray and be done. If you're a guy who likes to "wax" his car often then get Z5 or Z2.
You can just get the AIO if you want. It will still have a good shine and protection. ZCS will add protection too as well as a deeper shine if used on top of AIO.
Rejex is similar to AIO. It's a one and done product. Both have a slick feeling when dried. You'll find that Zaino is the most misunderstood product on here. Everyone thinks it's so much work. In truth it really isn't any different in application than anything else out there. There is a member who has built a very successful detail business in Silicone Valley using only Zaino products.
Race Car Tech
I just went down the Zaino road based on all of the great response on the forum. Nothing had been done to the car other than washing in quite a while so I started from scratch. I started by washing it with Dawn twice, gone over with Zaino Clay Bar then washed again (regular wash soap). Then three coats of Zaino Z-2 polish with a wipe down of Z-6 gloss enhancer between each coat. Glad it's over but well worth it.
I have used Rejex since 2003 on my first Vette a new 2003. So I love it even after 12 years of use and 2 different Vettes.
I put it on with my porter cable polisher. It dries to a haze in a few minutes depending upon the heat and humidity. It comes off so easy with a soft towel and there is NO dust. I wait 24 hours for the 1st coat to cure (as per the companies direction) then I put a 2nd coat on. The shine is great! When we travel I take final inspection with me, I spray it on the bugs guts and with very little pressure they just wipe off the paint.
My 2013 is torch red with crome/aluminum factory wheels. I rejex the wheels and the brake dust does not stick on the wheels like when I have used other products.
