Seat memory recall
Seat memory recall
Can't seem to get the memory recall to stay set. I will set the memory position for driving and the position for exit and they will work, but maybe next time they revert to some other setting. I have read the manual and followed all the directions, but no joy! What will fix this issue? JDA
Are you always using the same fob? Remember that are 2 different memory settings, one for each of fob #1 & fob #2.
And you did press the correct button on the door to save it for whichever fob you were using, right?
Same issue here it all started during the winter months here in Jersey, the seat moves up to the driver's position doesn't go back to let me exit without hitting my head!!
I have tried most all types of programing. It a 2006 auto vert. If I would disconnect the battery, would this cancel all previous settings? Then I could reprogram new settings. Would this help? JDa
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Fobs programmed for the car as fob #3 or fob #4 do not have access to memory options.
My 05 has done the same thing for ten years. The first thing to do is zip tie all the connectors under the drivers seat as shown. Move the seat up and back and pull them out. It's very easy to do. Make sure you pull them tight.
That made a big difference. Now occasionally it will do something strange and I reset it. Sometimes it will last 6 months or more other times less. It seems to have a mind of it's own.
