Corsa or Bolra
Corsa or Bolra
I'm trying to figure out which exhaust sounds the best Corsa or Bolra.
I'm wanting a exhaust that is noticeably louder than supercharged C6 Grand Sport. This car is really mean an I want the sound to match. I don't want a lot of drone noise but after 3k rpms I want it to sound as if all hell is breaking lose. I've been viewing corsa and bolra on youtube but almost all are on the Z06. I don't have that engine but I defiantly have the power to blow it out of the water. It would be nice if I could keep my NPP system. But if not then that's fine. Also haven't seen many old school flowmasters on vettes very curious as to what the 40 series would sound like couldn't find any on Youtube and I've herd that changing the headers out would give that deep sound. Please provide some input
Its Borla btw. Both manufacturers make multiple systems with different levels of sound output. You can't go wrong with either. If you want to keep bimode exhaust, then look up B&B Fusion or Akrapovic.
Both are good systems and sound excellent. My advice is to go to some car shows and ask Corvette owners if you could hear their exhaust before you put $$$$ into one for your car. I have the Corsa Extreme and am very pleased with it. Corsa makes more than one type of exhaust, so make sure you check their web site before you order. I know Corsa sport is not as loud as the extreme.
If you want loud but no drone, a corsa may be for you.
Corsa is known to not have any drone. But then again some people's opinion on no drone, little drone or LOTS of drone are all subjective.
I just installed my combo 2 weeks ago. Long tubes are long tubes really so in the end for me it was which exhaust i wanted. I wanted something loud but not obnoxious like my last car. Sound quality is a must over just how loud it can be. Not sense in being the loudest car on the block if it sounds like crap.
I ended up with a borla S-type to go with my long tubes and catless xpipe. The sound is PERFECT. Start up sounds amazing, idling is perfect, not loud at all really and when you get on the throttle, all hell breaks loose.
I have always said a corsa sounds amazing on a cammed car, stock cam doesn't sound as good. And that was the reason why it was easy for me to look elsewhere on exhausts.
I have Borla Attak's w long tube headers and hi flow Cats.....Sounds bad *** when you start up and get on the gas....but surprising quiet with no drone when cruising...
Highly recommend.
Highly recommend.
Attak
Hey the Attack is exactly the one I was looking at. My next question is do you have it on a LS3 or the LS7. I have the grand sport and the LS7 naturally sounds a lot meaner. Also by adding the long tube headers what size did you use and is it state legal.
Npp
Borla does have a NPP system but it's only for the C7 I haven't gotten an response from them in regards to the C6. It comes in the S / Attack modes. The perfect combination.
Shows
I've had both Borla and Corsa. My next set will be B&B (Billy Boat) Fusion dual mode. Gives you the option of loud or mild with the push of a button.
At 1500-1600rpm, the Borla will give you a headache. Corsa are nicely made, but have that higher pitch sound similar to a European car.
Get on YouTube and listen to some of the sound clips. An LS engine with a cam and headers equipped with a set of B&B mufflers is pure American muscle.
mhatton222 (09-15-2015)
I've had both on the same car. Has Corsa when I bought it already and I switched to Borla ATAK thinking it be louder. It's deeper but not louder. Neither have an drone. The ATAK is slightly louder at cruise bit nothing an average person would notice. My wife doesn't. The Corsa was louder under throttle inside the car but I think that's due to the higher pitch. Both were really nice but I'd still choose tge ATAK if I had a choice knowing what I know now. I just like the deeper tone.
It state legal. Finally, we started with the Borla S Type II exhaust, but my wife wanted more aggressive so on went the Attak's and we 100% satisfied.
Yep, just to add on...Borla Attak...think deeper tone....
Also, absolutely no drone. I think they had drone problems in their earlier exhaust systems, but not any more.
My car came with the NPP? By mode exhaust. I don't miss it at all.
Former Vendor
Borla's new systems (Atak, S-type II, and Touring) all have system specific mufflers with no drone. We are dealers for both and sell a lot of them. If you have questions, give us a call @ 443-730-9428. We would be glad to help you find an exhaust that fits you sound preferances and budget
Corsa has more off that newer V10 type higher tone pitch, while the Borla has more of the older 70's muscle car type lower tone pitch instead.
Since I would rather not having the vet sounding like a dump truck that is straight piped or something on a nascar track, lean more towards the sound tone of the Corsa instead.
Corsa sport
Corsa sport
Received 2,887 Likes
Corsa Sports for me. Put them on my 06 Vert. Sounded good.
Moved them to my 07 Coupe and added long tube headers, much better. A little deaper, def louder and more burble. No drown at cruise but very loud at WOT.
Corsa Sport - and never look back. Aside from sound, and a complete absence of drone, they are built from some of the very best stainless steel stock available. I've used the Corsa Sport exhaust systems on four different automobiles and have NEVER voiced a complaint !!
Note: Despite the caption on the video (2 or 3 posts "north" of mine,) I find it very hard to believe that that is correctly labeled as a Corsa Sport system - if anything, it sounds far more like the Corsa extreme, or another system altogether !!
Gary
