Help.
Help! Updated
2006 Coupe Automatic Trans
It's raining (again)
Car is on my QuickJack Lift. Outside under a canopy.Took the wheels off to detail three days ago. Raining since I took the wheels off.
While on the lift and waist high, I installed insulation (from a vendor on here) in the floorboards.
I also installed the SimpleConnect Bluetooth device (ISGM655).
I started the car just long enough to shift into N so I can clear the shift **** reinstalling the radio surround. Shut the car off. Surround in place. Placed shifter into P continued to finalize install. Car starts making clicking noises from the fuse panel area. I didn't think much of it. I realized I need to remove the radio surround due to an alignment issue with the center console. This is were it goes bad.
I just managed to get back into the car. Doors open and hood open now so I have access to everything.
UPDATE: Acts like a short in the system. dash lights flicker a little very hard to notice. Cargo are lights are bright. Radio/XM/NAV unit is making a noise like the eject disc motor running.
HOW CAN I MOVE THE GEAR SHIFT? Car will not start, automatic transmission,
I suspect something with the SimpleConnect since I mounted it right behind the FOB reader inside the dash. Severe interference or something. If can move the shifter, then I can remove the radio surround and disconnect the SimpleConnect device and trace out the problem.
Pouring down rain!
Pouring down rain!
Pouring down rain!
Pouring down rain!
Pilgrim
Well it's alive again!
Battery drained down. Low enough to make some lights act wacky and a couple of other little quirks.
Pulled the radio fuse. Stopped the noise from the radio. Hood light came on really bright. It was dime before I pulled the fuse. Hooked up to a jumper and let the jumper charge the vet for a little bit. Fired it up first try and let the vette alternator charge the battery for a while. This about when it stopped raining.
Made sure everything was working properly. Replaced the radio fuse. Everything is now working properly. A couple of restarts and little more charge time wrapped it up for the night.
I have a small trip to one of my offices in the morning, about 180 miles round trip. That ought to make sure the battery is back at 100%.
THANK YOU for responding to my help request!
