Alternator: Difference between AC Delco 25888970 & 25888971?
Hello,
Are there differences between AC Delco 25888970 & 25888971? My 2008 6.2L, MN6, Z51 (if that makes a difference) came with a 25888971, but all I can find are 25888970. Both seem to have the same mounting locations, connectors, and clocking of connectors. The labels both read 14V and 145A. Can a 25888970 be used as a replacement for 25888971?
Thank you
Thank you
That is a pretty good size alternator for a sports car.
I suppose that with all the electronics nowadays it should not be as surprise.
90 amps used to be big.
Someone will have an answer.
90 amps was big. My '74 Trans Am has the on-glass rear window defogger which added the "big" alternator...80 amps. The standard alternator on Firebirds at that time was 55 amps. The alternator models were 10SI and 12SI.
Not sure about the part numbers you posted as I'm traveling now, but automatic cars have a decoupler on the alternator.
Hello,
Thank you
Thank you
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
What 'VetteFan' stated ...
25888970 has a clutch decoupler built into the alternator's pulley (used in cars with the automatic trans)
25888971 has no decoupler built in the pulley (used in manual trans cars)
Personally, I am betting that you could use either one, no matter what transmission you have ... maybe I'm wrong ?
The following 2 users liked this post by Turbo6TA:
VetteFan0613 (03-13-2023),
vetteJPJ (03-12-2023)
Because of the higher inertia in the alternator at WOT shifting with an automatic GM uses Overruninng Alternator Decoupling (OAD) pulley. It wouldn't hurt using the OAD with manual. Probably why it's hard to find a non OAD replacement. Not using an OAD with an Automatic might reduce the longevity of ones alternator components, ie the alternator itself, belt and tensioner. They are other manufactures using the same principle, Audi and VW to name a few.
Turbo6TA (03-11-2023)
Either alternator will work just fine. Stop overthinking this stuff. If you need higher output buy this:
MECHMAN Made in USA. Not Mexixo or China.. High Output....around $600....and it's shiney. LOL
wjnjr (03-12-2023)
Turbo6TA (03-12-2023)
wjnjr ....
Can't remember if you told me or not .. Did you ever get that alternator I sent you to work? I believe that we figured out that it had a bad diode in it which caused the overvoltage problem.
I did a rebuild following Dano's instructions:
https://www.corvetteforum.com/forums...nator-fix.html
and it seemed to work OK. Voltage stayed between mid 13's and mid 14's depending on load, rpm, heat. The diodes actually checked out good and I never found anything obviously wrong when it was apart so I can't say exactly why the overvoltage was happening. I ran it on my car for about a week and then replaced it with a polished alternator I bought, keeping the decoupler pulley.
So yes, I got it to work, but I'm not 100% sure it's fixed for good because I didn't use it for very long.
Okie Dokie
It's the original alternator 25888971. I called a GM dealership, asked about the alternator - gave them my VIN number, the system only showed the 25888970 unit for my car. The parts clerk said the previous part number was 25888971. I cross checked this my Corvette mechanic. I'm installing the 25888970.
