G302 passenger side ground
I need to access the G302 ground point on on the passenger side door frame of my 05 to ground an amp, but I am not sure how to remove the trim piece. I've had the rear speaker panels off to install new coaxials, but from the diagrams I've seen the ground point appears to be behind the trim piece connecting the speaker panel to the trim piece at the bottom of the door opening. Pics would be great but even a description would be helpful. Thanks.
Remove the trim piece next to the glove box by pulling straight back towards the seat. Once it's loose, start to tilt the top downward as it has a tab on the bottom. Next, remove rocker panel by pulling straight up, starting at the rear. At about 45 degree start to pull towards the rear of the car. Now you can remove the rear panel covering the ground screw. Be careful with this one. Pry out slightly and look for clips. They will break easily if you happen to pull in the wrong direction.
Hope that helps.
Hope that helps.
Remove the trim piece next to the glove box by pulling straight back towards the seat. Once it's loose, start to tilt the top downward as it has a tab on the bottom. Next, remove rocker panel by pulling straight up, starting at the rear. At about 45 degree start to pull towards the rear of the car. Now you can remove the rear panel covering the ground screw. Be careful with this one. Pry out slightly and look for clips. They will break easily if you chappen to pull in the wrong direction.
Hope that helps.
Hope that helps.
