Stock muffler noise 07
Hi guys,
Seem to be getting a vibrating noise hum from the back end(stock mufflers) at idle, can hear it in the cabin. When I get on the gas and drive it goes away only at idle. I went underneath and tightened the muffler hangers and checked the hanger springs and everything seems fine. Never did this before was dead quiet at idle....seems when idle dips below 550rpm it hums. Any ideas
seems like something is loose or leaking.... maybe the baffle in the muffler
Doesn't sound like the torque tube bearing at least I hope not, that has a distinct paint can sound which I don't have.
Hi guys,
One last thing. 550 RPM was when the vibration started. No way to adjust it. I have had Five C6's. None of them vibrated with the stock or Corsa. None of them idled that slow either. Good Luck.
Take the hint. You are driving a Corvette, it is telling you that it needs to be heard. Dead quiet is not what it wants, it wants to be heard.
Most likely internal in the system.
