Run flat ruined?
Cruising
Run flat ruined?
My wife drove my 2010 GS home on a completely flat Goodyear Eagle Super Car EMT rear tire last night. While this would normally not be a concern, she apparently drove about 20 miles at normal highway speeds (75-80 mph).
I checked the tire when she arrived home - it looks completely fine but truly does have absolutely zero air pressure. I haven't located the source of the puncture as yet. Goodyear's website indicates that it is acceptable to repair a puncture in the tread area on a RFT. However, is this tire now unsafe because it was driven at sustained high speed with no air?
If I'm going to be replacing one half-worn 325/19 Goodyear, I would replace both rear tires. We all know these tires aren't very good anyway, so then instead I might be tempted to replace all 4 with another brand.
Contenders are the Bridgestone Potenza run-flats, or the Continental Extreme Contact (non-runflat). Am I asking for trouble putting conventional tires on a car with no jack or spare?
Thanks for any insights!
Received 1,675 Likes
I wouldn't trust that tire now buy you should speak with your Goodyear dealer. Also I always replace tires in pairs.
Received 2,836 Likes
2021 C6 of the Year Finalist - Modified
......after they have been run flat they can't be run again is what I have always heard. the sidewall is weakened because it has supported that side of the car for however long......and in your case they did a great job getting your wife home safe.
Go with the Stone-P's they are a great tire.....and its like your story why run flats are important to have........your wife would have been stranded and there might have been wheel damage if she did not catch the fact that the tire was flat with out the RF's........
I think you have to maintain 20 lbs of pressure to not ruin the tire....like if you have a slow leak and are driving to get it fixed....
Received 3,633 Likes
2016 C6 of Year Finalist
That's the good thing about a run flat, it will get to a safe place if within a reasonable distance. Bad thing, you get to buy a new one. I had a bad run flat Michelin and ended up buying all 4 tires. Did not want 2 new tires and 2 half worn tires, so the answer was replace all 4. I replaced with Continental DW's and carry a small compressor and plug kit. Any more than emergency patching a tire required then "here we go again, I've just bought another set of tires". I can almost get 2 sets of Conti's for the price of 1 set of "high dollar" tires.
Did the low air pressure sensor not work? The car should have given a warning that something was wrong and driver could have reduced the speed, even if just to remain within a safe speed for a run flat.
My wife DD our '64 vette during my 9 month deployment. When I returned I jumped in the car and it was running on 7 cylinders. When I asked when it started doing that (foolish question) she said "oh, about a week after you left"...
As if I didn't know better, a few years later she drove home in our '65 vette and the temp gauge was pegged and steam was coming out from under the car. When I asked how long it had been doing that (another foolish question) she said "oh, about 15 minutes"...
So, did the low air pressure sensor not work? It may not have mattered.
Cruising
I'm leaning towards the Conti's - just over $1100 for the whole set.
Exactly the same thing happened to our C6. I would not trust the run flats after they have been run any distance in a flat condition. I was not going to fix a 1/2 worn Goodyear tire! I bought 2 new Bridgestone Potenza R050A run flats and put them on the rear. Oh, by the way...there was 8000 miles on the Goodyears!!
Retired & lovin' it!
Depending upon how much mileage is on the current tires, you might chose to replace anyway, but as another has noted, best to check with a GY service tech. If the puncture is in a location that can be plugged & there is sufficient tread left on the tire, you may chose to do that. Keep in mind that a repair on a RF is not only a plug but also an interior patch, so the tire will have to be de-mounted (or at least the bean broken on one side).
As for non-RF's, I've been running Nitto Invo's for the past 20K miles without any problems. The ride is much more comfortable & quiet than the RF's, with no loss of handling. I do carry a plug kit & small 12v compressor, but have never had to use it. Also with a non-RF, if you do get a puncture, a plug alone is sufficient.
Repair it unless you have (too much) money you're trying to spend. And try a set of Firehawk RFs when your's need replacing. Great tires. I gotta laugh at the guys who replace a full set of tires when they need only one or a pair.
I had some nails in my GYRF on my old C5, they can be patched. I was broke and couldn't afford another tire, the shop patched mine, it can be done and your tire will be fine. Since it was in the rear I would thing that the pressure on the sidewall would be minimal compared to the front. I just let me drive my car, women just don't get it
I like the Conti's. Had them on my Z06 and running them on my base c6 now.
If a tire has been run 20% under inflated, it should be dismounted and the inside inspected for damage. A plug is only a temporary patch. Any tubeless tire that has a puncture that is not in a sidewall area must be dismounted and properly repaired with an internal patch. The only section of a tire that can be patched (not considered sidewall area) is any groove that has a wear bar present.
"Repair it unless you have (too much) money you're trying to spend. And try a set of Firehawk RFs when your's need replacing. Great tires. I gotta laugh at the guys who replace a full set of tires when they need only one or a pair."
I've got 1 new goodyear on the right front and a firestone with 4/32nd's on the left. Continental snow tire on the back left and a Bridgestone on the right rear that still has another 500 miles of use on it. All tires are good. I've saved almost $200. LOL
This is not a trailer we're talking about. Do what you need to do and make sure you have a good set of tires on the car. If the pulloffs have any life left in them, sell them to the Camaro guys.
used tires on ebay
There are some decent used tires for sale on E-bay, I bought a rear Michelin PS2 for my GS there a couple years ago and had no issues ,tire was as advertised with no patches or plugs. Word of caution, there are tires on there that have been 'professionally repaired' so read the fine print. I currently shopping for a no plug no patch used rear again (picked up a nail) and see several RFT GY for sale on e-bay.
Cruising
My original question was whether or not the Goodyear would be safe after being run at 75-80 mph sustained with no air. If it isn't, then I would have to replace it. If I have to replace it, then I have to replace the other rear tire since they're about half worn. I'm a huge stickler for having matching tires on my cars as far as brand/model/etc.
The point is - if I have to replace 2 tires anyway, now would be the time to get rid of the crappy stock tires.
Cruising
He said if it has been run at sustained high speed with no air, there could be all kinds of internal heat damage that cannot be seen even with the tire dismounted.
I think I'm going to err on the side of caution and toss it.
Just called the local Goodyear store. He said that if the tire was run at under 50 mph for under 50 miles, it could be salvageable pending the severity/location of the puncture.
