Is it my key FOB, door latch or what?
2013 GS. Yesterday, when I tried to get into my car with the remote, it would not open. The window would index down slightly like it should open but the door would not release. I went around to the passenger side and it worked fine. I reached across the passenger side to push the door release button and it still would not open. So, I then went to the trunk and released the door manually. I drove it home and then could not open the door with the electric door button so I had to open it with the manual release on the floor to get out.
Is this failure indicative of a weak battery on the FOB? Seems like I should have been able to open the door from the inside via the door button...Or, is this an issue with the door handle mechanism? Any ideas?
If it tries to open then the fob is working proper. The first thing I'd try is cleaning the outer door pad. There are many thread here on how to do it and it's very simple. If that doesn't work then you may need a new latch.
Check out THIS thread.
Thanks, EVRose, I will try that first. Since my inside door switch doesn't seem to work either, I thought I would try to narrow down my options. Seems like the contacts on the door pad are a good place to start.
If the door won't open from the inside when you press the button, then I doubt the problem is the contacts on the outside door switch, and cleaning them probably won't help. It sounds like the door release solenoid isn't working. I suspect a trip to the dealership is in your future.
