aFe New Pfadt Coilovers
Has anyone order the Pfadt coilovers from aFe Performance yet. I have been working with them to get replacement coilovers as I bought some used gen one pfadt coilovers and one of the rear ones had a blown shock. Unfortunately they cant fix mine. I have been back and forth over the Pfadt's and the Lg G2's. Cant decide if I want to have it adjustable or not. I think I will get a C6 Z someday so I would love to be able to just change them over and adjust accordingly. I do realize that I can put the LG's in a c6 z as well but it wouldn't be setup correctly as it would be coming off a C5 z. Anyone with any info on the NEW aFe coilovers please let me know what you think.
I have the LG G2s currently on my Z and I came from Pfadt SA Featherlights (before AFE) took over...so I don't know how the "newer" AFE Featherlights compare....
If you go with the LG G2s (which are awesome btw)...You could always send them back to LG to get them re-valved for when you get into a C6Z.
I was talking with LG and they told me about that option. Did you just not like having to mess with the Pfadt's or something? Why the switch to LG? What is it about the LG that you like more?
Lets just say I like the LGs because its a little more serious when it comes to street/track duties.
Heres my thread on the switch.
https://www.corvetteforum.com/forums...real-deal.html
thanks for the link. Looks like many other felt the same way you do. I do wonder if the sway bars had a big factor in it not handling the way you liked.
Good to know if i want to buy the same system that you have many have had great results.
Hi Gang,
with regard to the rear bar, we were never allowed to discuss this when Puff Daddy (pfadt) was in business but the rear bar does not function as a sway bar. It acts like an additional rear transverse spring.
When the car is on the ground at ride height, the arms are up over a 70 degree angle pointed up. Then as the suspension goes through its travel, instead of rotating the sway bar, it acts more like a transverse spring. Even on a straight run, both sides of the bar are pulled up instead of rotating the bar, it pulls up both sides of the bar.
Essentially it just adds spring rate to the rear by binding, but it does not act like an anti roll bar. (sway bar)
The angle of the arm, even with the car up on jacks, is already past the point where it will rotate the sway bar. Then when the car is set on the ground, there is no way to rotate the bar so it can act like a sway bar. on a video you can see the bar deflect up rather than rotate.
At LG Motorsports we have a slogan that says, "We race, you win". We could not have won so many pro races over the last 40 years if we made mistakes like this. (same goes for our Coil overs)
We already have 5000 miles of testing on our new C7 bars and coil overs. We are at the Corvette Museum 20 year bash as I write this. We will put up some video of our C7 on track with our Coil over shocks and Sway bars.
this thread would have been deleted a year ago. It is good that this info can finally be brought out.
Lou Gigliotti
note the angle of the arm even with the car on jack stands. Then imagine what it will do when the car is on the ground.
Lou Gigliotti
When switching over the LG G1 bars...I immediately noticed the car was substantially flatter around turns.
LOL! I'm actually not trying to be like that...I was looking at a few other options when I wanted to move on from the Pfadt stuff. I just found that the LG gear seemed to fit my needs better, and after installation...I am 100% pleased with the outcome. Lets just say...I was so disappointed with the Pfadt stuff on the track...I was looking for anything to get my car back to to feeling like it should. I almost went back to my leaf spring/DRM Bilstein setup which was great as well btw.
Whats next!! Just ordered the Camber kit from aFe. Then tires for my 18x10.5 square setup. after that just have fun for a while. Maybe sway bars next year.
