Backup camera install question
I just purchased a mirror mounted backup camera system for my base 2007. I previously installed one in my avalanche. After reading a couple of hours worth of threads here, I have this question;
I connected the camera to the reverse light (so it only comes on when in reverse)and the monitor to the auxiliary outlet. With the ignition off the monitor is still powered but the camera isn't, so I figured there would be no battery drain.
Is this wrong?
Is this wrong?
Is this wrong?
Is this wrong?
i havent measured the monitors but i have bench tested them using a regular 9volt smoke detector type battery and they work fine so they dont have many amps. generally speaking , we all have enough problems with battery drain with everything off that can be off, so i think actually intensionally adding drain is a bad thing.
NOTE: the wiper/heated seat has power only when car is running. When you finally get it all running and stable , drop by with pictures and what you think of it and how you installed it. We (i especially) would like to hear about it!!!!!
well, a couple things here. First that means the monitor is running 24/7, sounds like it will shorten the life of the monitor. The monitor uses very little power but how about hooking it up to the wiper/heated seat fuse using a fuse tap method?
Again, thanks for the knowledgable reply.
Hey coco,
You need one of these:
You can pick one up at autozone.
Then you just pull the fuse (wiper/heated seats), put this in, and make sure you put fuses in both slots in the tap a fuse.
Use the heated seat fuse, or the wiper fuse, as both are switched power. I don't recall the AC fuse being switched power, but I may be wrong. Someone else may be able to chime in and confirm that. You don't want to risk draining your battery when the car is off.
Also, for the monitor, so its not on the entire time, just use an on/off switch inline, so you can turn it off when not in use.
Those cheap monitors don't last long if you have them on the entire time.
fyi... local auto place will charge $16 (+/- $2) for them. you can go onto Amazon and look up "add a fuse" , you can get them cheap. Just have to make sure they are not coming on a slow boat from China'.
you have Amazon Prime and your set for quick delivery!
Good luck and let us see lots of pics and how your setup works for you when you are done.
NOTE: old install link https://www.corvetteforum.com/forums...tallation.html
i'd add more info in it about fuse tap (add a fuse) but strange things happen sometimes when you update a post you created. It disappears, what i mean is that you can NOT find it using ANY search words period anymore. Then in about 3 months (? or more) it sorta becomes searchable again. LOL
Last edited by ChevyDave; 09-05-2015 at 10:05 AM. Reason: added link to my old install post
Pikkashoe and Dave Thanks.
Dave, I read your "Front & rear backup / parking cameras , installation" before initiating this thread and bad me, didn't see "item P add a circuit".
I'll reread it again. This time a little more closely.
auto zone by me (Miami, FL) has the tap a fuse's for $5.99.
Must be regional differences in pricing.
coco, let me know if you have any questions during your install. Its pretty simple.
Dave's install link pretty much sums it all up and it very easy to follow.
