Reverse Lockout Solenoid Issue
I have done a search on here and google as well and cannot really come to a conclusion.
Since I've owned the car in april I've had this issue 3 times, until now.
The problem is that I can access the reverse gate while driving above 3mph. After a couple seconds of moving the shifter back and forth between the 5/6 gate and reverse I can feel the solenoid react and slowly lock it out. then its fine and works normally for however long.
Over the last few days its been everytime I drive the car. Ill go to shift into 5th and find that i am over in the reverse gate. After stopping and going a few times it will function as normal. So its as if the solenoid unit it "sticky"
Should I just replace the solenoid unit?
Ditto on changing it out, since it's easy enough to do, and should be able to find a new one for around $60 (gm part #12523300).
Also, since the solenoid is pretty much a sealed unit, it's not like you can get into it to clean up the plunger with electrical contact cleaner to begin with to solve it faulty problem.
