Why won't things stick to my windshield?
So the rearview mirror is fine but above the passenger seat, there is a black rectangular piece with some cables coming out of it. No idea what it is but the dang thing keeps falling off the windshield! It has a piece of tape that used to hold it on and I tried using command strips to reattach it to that and that didn't work so I got regular windshield adhesive and put that on. That held for 2 weeks and now it's fallen again... what is this part and what can I do to get it to stick?!
I'm definitely not using onstar but will getting rid of it limit my potential to use the microphone in the future? I intend to hook that up to the bluetooth unit I'm putting in eventually but haven't looked up the wiring map at all
I don't believe so, hopefully someone will chime in on that. I have read before that if you pull the wires out from behind the trim, there is a connection that can just be unplugged. Maybe do a search on it.
I'm guessing the alcohol is to remove residue of old adhesive?
Also, after researching it it seems that removing the whole unit is a pain because one of the wire bundles is important... as in the car won't start without it. I'm too lazy to rewire other stuff so I'll go with the clean and 3M tape
Received 2,051 Likes
St. Jude Donor '13
Randy got it exactly correct.
Our Onstar box was removed several years ago, we weren't using Onstar and the box annoyed my wife. We pulled out the wires, disconnected, and put it in the rear cubby in case I want to reinstall some day.
Didn't lose any function on the microphone, Bluetooth (2009 and later) works fine and the Nav voice commands are just as awful as they were before.
You aren't actually removing the OnStar module, just the 2 antennas. 1 for GPS (just OnStar nothing to do with the Nav) and 1 for it's cell phone.
Remove the visor clip screws and the header trim practically falls off, giving you access to the wiring harness. A-pillar trim just snaps off if you need more slack.
Unplug it and see what happens.
St. Jude Donor '13
