Do i need bigger brackets for z51 sway bars?
I just bought z51 sways for my base vette and went to put them on but the stock brackets that hold the sways on wouldnt fit. I got them to somewhat fit but the screws would only go one or two turns in because the brackets were sticking out. Am I doing something wrong or do I need bigger brackets?
You should have got new bushings with the sway bars that you will use with the factory brackets parts.
Hence the Z sway bars are wider OD, and need the bushing that are larger ID for them instead.
Yep ! Brackets are the same, you need bushings that have the correct inside diameter that matches the outside diameter of the bars you have.
Racer86
Racer86
So i got bushings that were bigger from the guy i bought the bars from but i couldnt get them to fit snug up in there. How far in did you guys screw the bars because my stock ones screwed in further for sure.
Please measure the bar outside diameter and bushing hole diameter. It should be very close to the same measurement. IE,, 7/8 inch bar,,,,, 7/8 hole plus or minus a little. if you find a big difference you may have the wrong bushings.
The "ears" on the bracket must be flat and mated to the frame , the bolts will pull tight when the bracket bottoms onto the frame. This will compress the bushing to the correct tension on the bars.
